Thank god for small favors...
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Kunal Ganguly
Sent: Friday, August 28, 2009 10:00 AM
Subject: Re: [Vantage] unable to pull in a field into a custom crystal
report
Tried that - no help. A customization tech at epicor said this was a
bug, but previously not known. I should be getting an SCR number here by
Monday (hopefully).
Kunal
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
Sent: Friday, August 28, 2009 9:34:46 AM
Subject: RE: [Vantage] unable to pull in a field into a custom crystal
report
I have seen that behavior at times. Go to pick links tab select
ProdCode, and then go to the description tab, select ProdCode for lookup
link, then fields pick add prodcode once again. This should get you
data..
Rob Bucek
FAX: (715)284-4084
<http://www.dsmfg com/>
(Click the logo to view our site) <http://www.dsmfg com/>
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Kunal Ganguly
Sent: Thursday, August 27, 2009 12:58 PM
To: Vantage Yahoo Group
Subject: [Vantage] unable to pull in a field into a custom crystal
report
Anyone ever had this issue before -
I created a copy of a data definition and pulled in a field that was
previously in the "excluded fields" section. I run a report using that
definition to generate the XML. In crystal reports, I can see the newly
added field, but it contains no data. I inspected the raw XML as well
and sure enough, the field header is there, but the tags (and data) for
the field are missing.
Report - Stock Status
Field - Part.ProdCode
Kunal
Rob Bucek
FAX: (715)284-4084
Of Kunal Ganguly
report
Monday (hopefully).
Kunal
report
data..
Rob Bucek
FAX: (715)284-4084
Behalf
Of Kunal Ganguly
report
Kunal
