Unable to See Full List of Assembly References in BPMs Custom Code
My Assembly References is short a lot of options, anyone else see this or have ideas on how to get the full list?
You can see the scroll bar here, I’m filtered on show 50 results, there’s closer to 35.
Using filter at the top, I get
It’s only showing results from what it had originally. No option to download more. Tried on 2 accounts, same results.
2600.100.7 - this is in the 3rd environment. It was working a couple of weeks ago max, but probably timed with the 100.7 update.
I’ll open a ticket as well, just hoping for a quick fix that I’m missing something obvious with.
it is bug in the grid it is being fixed. I wonder if @klincecum alternative References Speedup For Kinetic V2! - Case sensitive AND blazing fast 🤣 works
Sort of…At least using this BPM I could set a page # to return and I got to it that way. Thank you and Kevin for the workaround!
With my bpm, did you try just searching for ‘#’ ?
sorry i imported ReferencesSpeedupKineticWithCache BPM and looks like works in the back but table doesnt update:
That’s weird
