Unapprove PO when generating from New PO Suggestions
The system assigns the PO number for us so users cannot manually enter one, this would rule out the one concern I think. But if two buyers generate a PO at the exact same time there could be an issue there.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tuesday, February 14, 2012 11:12 AM
Subject: RE: [Vantage] Unapprove PO when generating from New PO Suggestions
You may also need to set ApprovalStatus = U.
There is a possibility of another buyer generating and having a later po number or a po number manually entered that is out of sequence and always last.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Sent: Tuesday, February 14, 2012 8:34 AM
Subject: Re: [Vantage] Unapprove PO when generating from New PO Suggestions
I this it to work using post-processing directive on the POSugg.Generate Method. I'm running this ABL code to unapprove the newly generated PO, does anyone think this wouldn't be reliable enough?
Find Last poheader Where poheader.Company = CUR-COMP no-error.
  if available poheader then do:
    poheader.Approve = false.
End.
From: tkoch77 <tkoch77@...<mailto:tkoch77%40yahoo.com>>
Sent: Monday, February 13, 2012 11:42 AM
Subject: [Vantage] Unapprove PO when generating from New PO Suggestions
Has anyone set up a BPM that handles this? I have tried pre and post processing method directives to set Approve to false with no luck. I am working with the PO.GetNewPOHeader method. When a buyer is generating from here the PO is automatically Approved which they dont want.
-Ted
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
-Ted
End.
-Ted
End.
-Ted
