Unattended Production time
We set up machine numbers as shop employees. At the end of each shift, the shift supervisor Ends Activity and clocks the "unattended machine numbers" out of the job when he reports the shift production. Then he Starts Production Activity again and clocks the ID for the unattended machine number back into the job for the new shift.
Lynn
--- In vantage@yahoogroups.com, "brz_larson" <bl_larson@...> wrote:
> If it always takes 36 hours, you could set up two operations.
> One for the labor part having both the labor and the machine as resources, the second with just the machine.
> or have the labor clock into the setup and clock out.
> In eiter case backflush the labor after the operation is complete.
> Does that help?
> Bruce
> www.ERPgeek.com
> bruce@...
> --- In vantage@yahoogroups.com, Michelle de la Vega <mdelavega@> wrote:
> > I have what might be a dumb question, however, I am a little lost.
> > How does this group hand unattended production time? For instance we have a part that takes 4-5 man hours, but the machine/resource runs for 36 hours. Do you add this to the burden rate of that operation? Or does Vantage know how to handle this?
> > Any advice would be greatly appreciated.
> > Thanks,
> > Michelle de la Vega
> > Business Applications Manager
> > Cold Jet, LLC
> > 455 Wards Corner Road
> > Loveland, Ohio 45140
> > USA
> > +1 513-716-6400 (office)
> > +1 513-382-3281 (mobile)
> > +1 513-831-1209 (fax)
> > www.coldjet.com<http://www.coldjet.com>
> > [cid:image001.jpg@]
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@01C9D48C.544C5B50]
Does that help?
Bruce
www.ERPgeek.com
bruce@...
> Thanks,
> Michelle de la Vega
> Cold Jet, LLC
> USA
> [cid:image001.jpg@...]
