Uncheck Production Yield
We are looking to set ProductionYield on all jobs that got batched except for the batch job. I hope I am close to the solution. I have created a BPM for Job Entry.Update instead of SchedulingBoard.BuildJobLine. I was getting an error saying ‘SchedulingBoardTableset’ does not contain a definition for ‘JobHead’ and no accessible extension method ‘JobHead’ accepting a first argument of type ‘SchedulingBoardTableset’ could be found (are you missing a using directive or an assembly reference?)
Below is the code I have, and it compiles with no errors. It doesn’t seem to do anything; that is why I am wondering if I have it tied to the wrong method directives. Or should I use this in a function instead and call it from an event in Application Studio? Any help would be greatly appreciated. I am willing to bet we are not the first company to try this.
THIS IS A TEMPORARY FIX. We are developing a massive customization to streamline the whole batching process, but it will not be ready for go-live before the end of the month. So if you have a solution held together with duct tape, that sounds perfect!
var ttRow = ds.JobHead.FirstOrDefault();
var ttRow2 = ds.JobProd.FirstOrDefault();
if(ttRow != null)
  string jobNum = ttRow.JobNum;
  var jobSvc = Ice.Assemblies.ServiceRenderer.GetService<JobEntrySvcContract>(Db);
  var jobDS = jobSvc.GetByID(ttRow.JobNum);
  bool ProdYield = ttRow.ProductionYield;
  string TargetJobNum = ttRow2.TargetJobNum;
  if (ProdYield == true)
    if (TargetJobNum !=  string.Empty)
        ttRow.JobNum = ttRow2.TargetJobNum;
        ttRow.ProductionYield = false;
        jobSvc.Update(ref jobDS);
BPM under the ERP.BO.BatchOps.DoBatching
try
    List<string> parsedList = string.IsNullOrWhiteSpace(opRowIDList)
    ? new List<string>()
    : opRowIDList.Split(',')
               .Select(item => item.Trim())
               .Where(item => !string.IsNullOrEmpty(item))
               .ToList();
    foreach (string oprID in parsedList)
        Guid oprGuid = Guid.Parse(oprID);
        JobOper jobOper = Db.JobOper.Where(x=>x.SysRowID == oprGuid).FirstOrDefault();
        if (jobOper != null)
              JobHead jobHead = Db.JobHead.Where(x=>x.Company == Session.CompanyID && x.JobNum == jobOper.JobNum).FirstOrDefault();
            jobHead.ProductionYield = false;
            Db.SaveChanges();
catch{
