Undo job receipt on serial number tracked parts?
If you don't have this solved yet ... here's how we work around this in 8.03.405.
Put the quantity you want to return as a positive, enter your SNs, then come back and change the quantity to the negative qty before you save.
--- In vantage@yahoogroups.com, rob.sample@... wrote:
> Using 8.03.408B and I can not find a way to undo a job receipt to inventory for SN tracked parts. Parts were received against the wrong job and I am trying to back out the receipt so that they can be re-received against the proper job. I have tried putting negative qty in the job receipt to inv screen, but when I click on SNs it brings up a SN detail screen which has no place to add, select, or enter serial numbers.
> I was on the phone with Epicor for 40minutes and got no help at all.
> Does anyone have a workaround for this? Am I doing something wrong?
