Uninstalling Epicor 9.04 Error 1606
Thanks for the advice everyone. We will not be loading Epicor back on this machine as it is an older machine that has an older version of Epicor we are no longer using. We have since bought a dedicated server to install our main instance of Epicor on. I was just trying to free up space on it the best way possible.
Jeff Purvis
J&T Distributing
859-745-7956
www.jtfoc.com
----- Original Message -----
Sent: Wednesday, November 14, 2012 10:41 AM
Subject: [Vantage] Re: Uninstalling Epicor 9.04 Error 1606
I am going to 2nd this !
I never setup any server that I plan to keep around without doing a full wipe and re-install of the OS.
I also recommend that you consider the drive configuration and try to spread the load between drives as best as possible.
Neil
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> Just my 2 cent, but I would seriously suggest wiping the server and loading
> clean. Re-purposing an old server is just asking for issues.
> *John Driggers*
> *Chief Data Wrangler*
> *I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
> *:: 904.404.9233
> :: waffqle@...
> :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> On Tue, Nov 13, 2012 at 1:37 PM, Jeff Purvis <jeff.purvis@...
> > wrote:
> > Thanks. I assumed it was the server components for an earlier version
> > install. We are cleaning the server up to use as something else and this is
> > the first time I've even logged into it. I'll just delete the folder's.
> > Thanks,
> > Jeff Purvis
> > J&T Distributing
> > 859-745-7956
> > www.jtfoc.com
> > From: Ned
> > Sent: Tuesday, November 13, 2012 1:32 PM
> > Subject: RE: [Vantage] Uninstalling Epicor 9.04 Error 1606
> > Are you trying to uninstall the server components or the workstation
> > components?
> > I usually just tell people to delete the folder it's installed in and not
> > worry about anything else.
> > Sounds like it's trying to find the path to the clientinstall.exe on the
> > server that possibly no longer exists.
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of
> > jeff
> > Sent: Tuesday, November 13, 2012 1:24 PM
> > Subject: [Vantage] Uninstalling Epicor 9.04 Error 1606
> > I'm trying to uninstall Epicor 9.04 from one of our old machines. I receive
> > the following error: (Error 1606. Could not locate network connection x.)
> > It then stops the uninstall. Any idea how to get around this?
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
I'm trying to uninstall Epicor 9.04 from one of our old machines. I receive the following error: (Error 1606. Could not locate network connection x.) It then stops the uninstall. Any idea how to get around this?
components?
jeff
Thanks. I assumed it was the server components for an earlier version install. We are cleaning the server up to use as something else and this is the first time I've even logged into it. I'll just delete the folder's.
Jeff Purvis
J&T Distributing
859-745-7956
www.jtfoc.com
components?
jeff
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> Thanks,
> Jeff Purvis
> J&T Distributing
> 859-745-7956
> www.jtfoc.com
> From: Ned
> components?
> Of
> jeff
Neil
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > Thanks,
> > Jeff Purvis
> > J&T Distributing
> > 859-745-7956
> > www.jtfoc.com
> > From: Ned
> > components?
> > Of
> > jeff
