UnitPrice vs DocUintPrice
Look at the currency exchange rate on the invc header.
On Jul 18, 2011, at 11:28 AM, "Mordechai" <mseal@...> wrote:
> We have seen this issue and at times the value is not $0 but actually a different value.
> We believe (but could not re-create it) that it is caused during the push or pull wizard from a quote and that the user changes the prices from the quoted value to the new order value.
> We have opened an case for this, but will little time to prove and recreate this, guess is will close on me…
> Motty
> --- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> > In Epicor 9.05, DocUnitPrice & UnitPrice work exactly as Linda
> > describes, differing only by currency. I did see some zeros for one of
> > them when our exchange rates got messed up, so I'd look there for a
> > problem. Note that the rate type is set when the order is created, and
> > fixing the default rate type in your company configuration only affects
> > new orders, so it won't clean up a problem with an old order.
> > Brian.
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of Linda Lowney
> > Sent: Monday, July 18, 2011 11:05 AM
> > Subject: RE: [Vantage] Re: UnitPrice vs DocUintPrice
> > Hi Bruce,
> > Oh, I have never seen that. We are still on 8.03 so maybe it is a new
> > "feature" of 9.
> > Regards,
> > Linda
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of cooner_55421
> > Sent: Monday, July 18, 2011 11:01 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Re: UnitPrice vs DocUintPrice
> > Hi Linda,
> > I don't think it is the currency.
> > When they are off - one value will be zero.
> > So records look like this:
> > UnitPrice, DocUnitPrice
> > 0.00, 12.00
> > 1.59, 0.00
> > 0.68, 0.00
> > When I check downstream, invoices are using the unitprice in totals.
> > Examples I have checked, this seems correct.
> > But, we have trouble because reports and dashboards are using both
> > DocUnitPrice or UnitPrice. Confuses end users.
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > <mailto:vantage%40yahoogroups.com> , "Linda Lowney" <llowney@> wrote:
> > > Hi Bruce,
> > > Did you check the customer's currency. The DocUnitPrice is in the
> > > currency of the customer, the UnitPrice is in your base currency.
> > > Linda
> > <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> > <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
> > On Behalf
> > > Of cooner_55421
> > > Sent: Friday, July 15, 2011 5:40 PM
> > > Subject: [Vantage] UnitPrice vs DocUintPrice
> > > Hi,
> > > Just wondering if any of you have seen cases where the UnitPrice does
> > > not match the DocUnitPrice in the OrderDtl table? E9 9.04.506.
> > > I'm seeing a few mismatches.
> > > I was told by tech support that they have heard of them getting out of
> > > sync if an order is changed several times.
> > > And, that if they do get out of sync in teh OrderDtl table - UnitPrice
> > > is the value I should rely on.
> > > UnitPrice is supposed to be used in subsequent processing of Shipments
> > > Invoicing.
> > > Thanks,
> > > Bruce
Hi Bruce,
Linda
Of cooner_55421
Hi,
UnitPrice is supposed to be used in subsequent processing of Shipments &
Invoicing.
Bruce
Hi Bruce,
Oh, I have never seen that. We are still on 8.03 so maybe it is a new “feature” of 9.
Regards,
Linda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
Hi Linda,
0.00, 12.00
1.59, 0.00
0.68, 0.00
But, we have trouble because reports and dashboards are using both DocUnitPrice or UnitPrice. Confuses end users.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Linda Lowney" <llowney@...> wrote:
> Hi Bruce,
> Linda
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
> Of cooner_55421
> Hi,
> Invoicing.
> Thanks,
> Bruce
Brian.
Of Linda Lowney
Hi Bruce,
"feature" of 9.
Regards,
Linda
Hi Linda,
0.00, 12.00
1.59, 0.00
0.68, 0.00
> Hi Bruce,
> Linda
On Behalf
> Of cooner_55421
> Hi,
> Invoicing.
> Thanks,
> Bruce
We have opened an case for this, but will little time to prove and recreate this, guess is will close on meÂ…
Motty
> Brian.
> Of Linda Lowney
> Hi Bruce,
> "feature" of 9.
> Regards,
> Linda
> Hi Linda,
> 0.00, 12.00
> 1.59, 0.00
> 0.68, 0.00
> > Hi Bruce,
> > Linda
> On Behalf
> > Of cooner_55421
> > Hi,
> > Invoicing.
> > Thanks,
> > Bruce
