Unmatched delimiter found error
SaaS PILOT environment with a client beginning to clean up for MRP. The MRP process ran, and now I’m trying to run the Production Planning Process to populate the Production Planner Workbench… but when I submit the process it errors out almost immediately with:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: Ice.Common.SqlSecurityException: Unmatched delimiter found: ".
I searched the forum for “unmatched delimiter”, but no results. EpicCare KB search also returned empty. I’m hoping there’s this stupid little thing I’m forgetting… but I’m still forgetting it. Any ideas?
In this case, I had to select the option to “ignore non-stock materials”. With that selected, the process ran correctly and populated the dashboard.
