At 11:37 AM 9/25/2000 , you wrote:
If you want to watch what it does, you can use: COMMAND /Y /C {batch file
command} to display each line of the batch file (with the variables
expanded) and confirm each one before running it.
Also, this batch file does not attempt to remove every trace of Progress
and Vantage. Just certain .OCX files. So you will still find various
\DLC\ references. Norton Utilities has a nice registry cleanup utility, BTW.
-Wayne
>type unregocx v ......do not put a colon or backslash. this shouldI just looked through the .BAT file, and it should work the way Dick says.
>run quite fast
>type unregocx c same thing no colon, no backslash.
-Wayne
