UOM Class Weight
on the revision tab, right click in the revision field, open with Method Tracker
--- In vantage@yahoogroups.com, khambleton500@... wrote:
> Brenda,
> That did it!!!! Thank you.
> One other question...now that I have a material associated with a part where can I view it? In Vantge 6.1 you can see the BOM under the revision tab, but I'm not seeing it in E9.
> Thanks,
> Kathy
> From: Belinda H <bshannah1@...>
> To: vantage@yahoogroups.com
> Sent: Sun, 01 May 2011 20:07:43 -0000 (UTC)
> Subject: Re: [Vantage] Re: UOM Class Weight
> This is really going to sound weird but all we did was add a UOM class
> called weight and we had no more problems with the Engineering Workbench.
> Did not attach it to any part numbers (that is the weird part).
> Belinda
> On May 1, 2011 3:22 PM, "cooner_55421" <cooner_55421@...> wrote:
> > Hi Kathy,
> > I can only guess that you need to look at the part masters, UOM & UOM
> Class Maintenance.
> > Do you have nay more details?
> > Did you perform a test upgrade? From 8.03.xx of 6?
> > BTW going from 8.03.xx to 9...
> > UOMs were the hardest part of the upgrade process for me to get straight.
> > --- In vantage@yahoogroups.com, khambleton500@ wrote:
> >> Hi all,
> >> Hopefully someone can help me! We are in the process of setting up Epicor
> 9 version E9.05.602A for testing. I am trying to add materials and
> operations to a part revision through the engineering workbench. I get the
> following error message:
> >> UOM Class Weight was not found.
> >> I can not figure out what or where this field is.
> >> Thanks,
> >> Kathy
> >> Electron Energy Corporation
> >> [Non-text portions of this message have been removed]
I would like to have MES do autologon on shop computers, I used to be able to do it in the Data collection.mfg file in 6.1. I am sure there is a way just not sure how, I had the data collection signing on with the same username password.
Thanks in advance for any suggestions
In 9.05, the default.mfgsys file in the client/config folder is the
equivalent file. Look for this section:
<userSettings>
<!-- provide values for UserID and Password to enable auto-login -->
<UserID value="username-here" />
<Password value="and-password-here" />
<SingleSignOn value="false" bool="" />
<DataCollectionUser value="true" bool="" />
Brian.
Of pabru
Sent: Friday, March 18, 2011 4:21 PM
Subject: [Vantage] MES auto logon
Thank You!, That is exactly what I was looking for.
--- On Fri, 3/18/11, Brian Roberts <broberts@...> wrote:
Subject: RE: [Vantage] MES auto logon
Date: Friday, March 18, 2011, 3:46 PM
Â
<userSettings>
Brian.
Of pabru
Hi all,
Hopefully someone can help me! We are in the process of setting up Epicor 9 version E9.05.602A for testing. I am trying to add materials and operations to a part revision through the engineering workbench. I get the following error message:
Kathy
Belinda
> Hi Kathy,
Class Maintenance.
>> Hi all,
>> Thanks,
>> Kathy
We are doing a clean install, using DMT to import our master files from Vanatge 6.
I have looked in all three tables you mention below but haven't had any luck. On further thought, I'm wondering if the process is looking for a UOM Class titled Weight. Which would tell me that a part must have a UOM Class of Weight. So I ran a BAQ on the PartUOM table but that didn't help. In UOM Class maintenance I only have 1 class set up, which is COUNT and it has several UOM's associated with it but none are weight. What table would give me a listing of parts and their UOM Class?
Kathy
Sent: Sun, 01 May 2011 19:22:33 -0000 (UTC)
Subject: [Vantage] Re: UOM Class Weight
Hi Kathy,
I can only guess that you need to look at the part masters, UOM & UOM Class Maintenance.
> Hi all,
> Thanks,
> Kathy
Brenda,
Kathy
Belinda
> Hi Kathy,
Class Maintenance.
>> Hi all,
>> Thanks,
>> Kathy
