UOM Conversion 8-9
What are your UOM class types? If you have class types of other you can add the uom to each class. If the types are the Epicor controlled class, then the UOM can only be attached to one class.
I was advised to create all of our own UOM classes with a class type of 'Other'. With this strategy you can also make the uom part specific. This helps when you have units of measure of 'BT' and want to go to 'OZ'.
Tom Osen
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Lol maybe during conversion our left's you. But you can't do it manually
> On Sep 7, 2012 4:24 PM, "John Driggers" <waffqle@...> wrote:
> > Then how do I have gallons in both volume and count? =)
> > WHY I have that is a whole other conversation...
> > *John Driggers*
> > *Chief Data Wrangler*
> > *I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
> > *:: 904.404.9233
> > :: waffqle@...
> > :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> > On Fri, Sep 7, 2012 at 2:34 PM, Jose Gomez <jose@...> wrote:
> > > No you create
> > > FLOZ and OZ
> > > You can't have the same Unit in two classes.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > *T: 904.469.1524 mobile
> > > E: jose@...
> > > http://www.josecgomez.com
> > > <http://www.linkedin.com/in/josecgomez> <
> > http://www.facebook.com/josegomez
> > > <http://www.google.com/profiles/jose.gomez> <
> > http://www.twitter.com/joc85>
> > > <http://www.josecgomez.com/professional-resume/>
> > > <http://www.josecgomez.com/feed/>
> > > <http://www.usdoingstuff.com>
> > > *Quis custodiet ipsos custodes?*
> > > On Fri, Sep 7, 2012 at 2:06 PM, John Driggers <waffqle@...> wrote:
> > > > I BELIEVE you can either use the same one in both, or you create 'OZ'
> > > under
> > > > each class and it knows the difference.
> > > > It's been a while since I set it up, but I know we OZ under each with
> > the
> > > > same ID.
> > > > *John Driggers*
> > that?*
> > > > *:: 904.404.9233
> > > > :: waffqle@...
> > > > On Fri, Sep 7, 2012 at 1:59 PM, Ned <TechnoBabbly@...> wrote:
> > > > > Just curious what other people have done for Ounces OZ since it can
> > be
> > > > both
> > > > > a volume as well as a weight.
> > > > > Can you have the same UOM in 2 classes? Or did you change things up
> > and
> > > > > make
> > > > > a new UOM like LOZ for Liquid Ounce.
> > > > > [Non-text portions of this message have been removed]
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > > have already linked your email address to a yahoo id to enable access.
> > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > > Crystal Reports and other 'goodies', please goto:
> > > > http://groups.yahoo.com/group/vantage/files/.
> > > > (2) To search through old msg's goto:
> > > > http://groups.yahoo.com/group/vantage/messages
> > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
Just curious what other people have done for Ounces OZ since it can be both
Can you have the same UOM in 2 classes? Or did you change things up and make
I BELIEVE you can either use the same one in both, or you create 'OZ' under
It's been a while since I set it up, but I know we OZ under each with the
same ID.
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> make
No you create
FLOZ and OZ
*Jose C Gomez*
*Software Engineer*
E: jose@...
> same ID.
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> both
> > make
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> No you create
> FLOZ and OZ
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> under
> > same ID.
> > *John Driggers*
> > *:: 904.404.9233
> > :: waffqle@...
> > both
> > > make
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > No you create
> > FLOZ and OZ
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > under
> the
> > > same ID.
> > > *John Driggers*
> that?*
> > > *:: 904.404.9233
> > > :: waffqle@...
> be
> > > both
> and
> > > > make
> and
