The acceptable solution has been found. You are exactly right Tim, if I
print preview it does not ask for the printer and uses the default. It then
does not care what type of port it is on and prints to the jetdirect card
just fine. I find this an acceptable answer to the problem. I have tried
several drivers with no luck, but the print preview works. I think the
purchasing manager can life with the extra 4 minutes this will
take...especially since he is about to order the processor, memory and hard
drive upgrade for the vantage server to bring it out of the dark ages. For
the week until he gets the speed he will be begging for, he will live with
it.
Thank you all for the responses you gave. The problem is now solved.
Thank you all so much.
Aaron Hoyt
System Administrator
Design Standards Corp.
PO Box 1620
Charlestown, NH 03603
Tel 603-826-7744
<mailto:Aaron@...>
Sent: Friday, December 08, 2000 8:39 AM
To: vantage@egroups.com
Subject: Re: [Vantage] Up to here with printing...
This sounds like a problem that we had with report builder through
custom report links. When we ran the report and tried to print directly
to the printer, we got the same error. But, when we did a print preview,
the report would come up, and then could be printed from there. It seems
to me that it had something to do with a LaserJet 5p driver, but I can't
remember exactly. I moved that printer into an area not used by Vantage.
Good luck.
Tim Care
Electro Chemical Finishing
it.
Aaron Hoyt
PO Box 1620
Tel 603-826-7744
<mailto:Aaron@...>
> I can print reports from (within) report builder fine from any computer,Aaron,
> even the ones that are not working right. But, if I go to custom report
> links in vantage and try to print the report from there I get the message
> that the printer is not installed or the port is not available. So for
Good luck.
Tim Care
