Updatable BAQ Blank Title 96727
Yeha Ive' got it working using the BO's but it would be faster using an updatable BAQ that I call through a customization.Â
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
     Â
On Fri, Dec 20, 2013 at 11:07 PM, <rubensjunqueiramaia@...> wrote:
Â
<div>
  <p></p><p>Price Lists are very tricky. I spent a whole morning with an Epicor developer on it - in the end we agreed that a simple change to the source code (which took her 15 minutes) was the better way. This was the only source code change we had in the whole project, which ended up with over 100 BPM&#39;s </p>
</div>
<div style="color:#fff;min-height:0;"></div>
Has anyone been able to get an Updatable Dashboard to work on a menu? I am able to get it to work in development, but once I deploy it to the Main Menu, the updatable part of the dashboard will not work.
Rick
Rick,
what version of 905 are you on
there was an issue with starting the BAQ from the table that is to be updated and a solution was to have another table call the updatable BAQ part
Motty
> Thanks,
> Rick
We are on 9.05.600b and have updateable BAQ's that work, but have not gotten an updateable dashboard functional yet either. The table work around my help me out, thanks.
Brad Boes
Metalworks
--- In vantage@yahoogroups.com, "Mordechai" <mseal@...> wrote:
> Rick,
> Motty
> > Thanks,
> > Rick
How are you placing them on the menu. We had to put them on the menu as a Dashboard-Assembly. We do have a couple of Updateable Dashboards running here but they are really a pain to maintain.
We are also running 9.05.600b
Gene McDonald
M. Holland Co.
> Brad Boes
> Metalworks
> --- In vantage@yahoogroups.com, "Mordechai" <mseal@> wrote:
> > Rick,
> > Motty
> > > Thanks,
> > > Rick
Gene,
I checked, and I did use the Dashboard-Assembly.
Rick Hagy
HMU, LLC.
Of gmcdonald333
Sent: Thursday, January 13, 2011 6:57 AM
Subject: [Vantage] Re: Updatable BAQ
Gene McDonald
M. Holland Co.
> Brad Boes
> Metalworks
> > Rick,
BAQ part
> > Motty
> > > Thanks,
> > > Rick
Has anyone cracked the code to run an updatable dashbaord by code and update it?
I’ve been trying but there are ton of different datasets and variables.
Jose C Gomez
Software Engineer
E: jose@...
     Â
Hi Jose what are you trying to update? Can you give an example?
I can update anything using an updatable bbq in this case it was price list part break but I wanted to do it in code
On Dec 20, 2013 6:36 PM, <rubensjunqueiramaia@...> wrote:
Â
<div>
  <p><p>Hi Jose what are you trying to update? Can you give an example?</p>
</div>
Price Lists are very tricky. I spent a whole morning with an Epicor developer on it - in the end we agreed that a simple change to the source code (which took her 15 minutes) was the better way. This was the only source code change we had in the whole project, which ended up with over 100 BPM's
