Thanks John & Jose!
John,
Easy as pie, easiest ABL I've ever messed with!
And thanks for the explanation and alternate code, I think I will try that since some cases I found we are updating 100+ OrderRel records and that seems to take awhile (respectively).
Either way, it works and I learned something new about FOR EACH!
Do you do ABL programming training?
-Rick Bird
IT Software Administrator
Rowmark, LLC.
John,
-Rick Bird
Rowmark, LLC.
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> Jose is correct, UpdateTableBuffer is just a way to get around the fact
> that Epicor didn't allow DB writes in version 8.
> As far as 'find first', 'if avail' etc, that's just a different way to
> search. If you just need one record, you can do
> FIND FIRST Table WHERE X = Y.
> The 'IF Avail' is just used so the code doesn't try to execute against an
> empty result set. If you use the FOR EACH syntax, it handles that
> automatically. It fetches all the records that match and loops through
> them. If it doesn't return anything, it doesn't loop. There are situations
> where the 'FIND FIRST' method is the only way to go, but you'll know one
> when you come across it. Generally it's preferable to use the 'FOR EACH'
> syntax anytime you can get away with it. If nothing else, it's less wordy
> and easier to read.
> Generally you want to check the RowMod so you can find rows in the TT
> tables that were updated or appended. It's pretty common when updating
> order lines or something similar that you only want to edit the line being
> modified. RowMod lets you find that row without jumping through a lot of
> hoops.
> It's good habit to use rowmod lest you accidentally update the wrong
> record; though in this particular case you may not really need it. You want
> to find and update all the releases for the orderheader --assuming I'm
> following you correctly. If the only thing people are editing is the ship
> date, you can safely fire it everytime as the BPM wouldn't be called if it
> hadn't been changed. If you want to be a bit more slick and save a little
> work for you DB you could do the following:
> FOR EACH ttOrderHed WHERE ttOrderHed.RowMod <> '',
> EACH OrderRel WHERE OrderRel.Company = ttOrderHed.Company AND
> OrderRel.OrderNum = ttOrderHed.OrderNum AND OrderRel.ShipDate <>
> ttOrderHed.ShipDate:
> /* Do you assignments and whatnot here */
> END.
> That will only run against releases with shipdates that don't match the
> order header. Double check the field names, I'm going off the top of my
> head.
> *John Driggers*
> *Chief Data Wrangler*
> *I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
> *:: 904.404.9233
> :: waffqle@...
> :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> On Wed, Aug 8, 2012 at 2:53 PM, Jose Gomez <jose@...> wrote:
> > If you are in version 9X you don't need to use UpdateTbalebuffer
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@...
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <
> > http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <
> > http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > <http://www.usdoingstuff.com>
> > *Quis custodiet ipsos custodes?*
> > On Wed, Aug 8, 2012 at 2:35 PM, that_guyy <rbird@...> wrote:
> > > JOhn,
> > > Thanks for the code & validation. I've been reading about the
> > > recommendation to use the 'Run lib\UpdateTableBuffer.p()' instead, is
> > there
> > > a way to do that instead? Is this a 'safer' way... or with what I am
> > trying
> > > to do (for each) does this just get messy.
> > > I am assuming your bit of code is more or less a sample, I still need to
> > > do all the RowMod value checks and the 'find OrderRel where' and 'if
> > avail'
> > > stuff, right?
> > > Sorry, I know just enough ABL to be dangerous.
> > > Thanks,
> > > -Rick Bird
> > > Rowmark, LLC.
> > > --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > > > You're correct, you should be able to basically do:
> > > > FOR EACH ttOrderHed,
> > > > EACH OrderRel WHERE OrderRel.OrderNum = ttOrderHed.OrderNum:
> > > > ASSIGN OrderRel.Field = Value.
> > > > END.
> > > > Adjust your where clause appropriately, but that should do it.
> > > > *John Driggers*
> > that?*
> > > > *:: 904.404.9233
> > > > :: waffqle@
> > > > On Wed, Aug 8, 2012 at 12:14 PM, that_guyy <rbird@> wrote:
> > > > > I have an updatable dashboard that displays a list from OrderHed of
> > > Orders
> > > > > on Hold and no ship by date specified. Both fields are updatable. The
> > > idea
> > > > > was that our Customer Service could quickly set the shipby date and
> > > take
> > > > > the order off hold, which works except, since it's an updatable BAQ
> > BPM
> > > > > that does the update and not base, the Sales Order releases are not
> > > getting
> > > > > their ship by date updated (like it does in Order Entry).
> > > > > What I think I can do is add to the ABL code on the Updatable BAQ BPM
> > > to
> > > > > update all the releases for that sales order to match the new ship
> > > date.
> > > > > Other than 'reading' a value from a table, I have never tried to
> > update
> > > > > data to a table directly, I have always used what ever tt fields that
> > > were
> > > > > available to me in the BPM, in this case the OrderRel is not
> > available
> > > to
> > > > > me, how do I 'get it'?
> > > > > Then I was thinking I could use a 'for each...' type of query or
> > > whatever
> > > > > to loop through all the OrderRel records and update the date.
> > > > > Any help on this would be most appreciated!
> > > > > -Rick Bird
> > > > > Rowmark, LLC.
> > > > [Non-text portions of this message have been removed]
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
