Updatable BAQ
I created an updatable BAQ and I would like one of the updatable fields to be a pulldown, does a setting exist to force this? On one of my other BAQs this seemed to happened by default.
Rich,
In the BAQ Designer under Update\General Properties tab there is Advanced Column Editor Configuration. You’ll find the ability to set that there. Editor Type to Drop Down list, and you can hand jam your list or use another BAQ to populate it etc…
Thanks Rob, It was what I was looking for.
@rwagner if @rbucek solved your problem give him credit by marking the problem solved. This helps others later find the answers more easily. :slight_smile:
