Updatable Query
Thank you everyone for your responses. I had to call Epicor Support and my issue was a lot deeper than it initially appeared. They still do not know what is going on but, they are working on it.
Thanks again.
Millicent
Sent: Thursday, September 18, 2014 12:48 PM
Subject: RE: [Vantage] Re: Updatable Query
I am getting a different message that states
“Warning! BPM Directives for 'query name’ updatable query were not generated.
Sent: Thursday, September 18, 2014 12:36 PM
Subject: [Vantage] Re: Updatable Query
Once you get your list, double click on the row. Make you changes and click Update. To add a row you click on Get new.
Carol
This message is intended only for the addressee and may contain information that is company confidential or privileged. Any technical data in this message may be exported only in accordance with the U.S. International Traffic in Arms Regulations (22 CFR Parts 120-130) or the Export Administration Regulations (15 CFR Parts 730-774). Unauthorized use is strictly prohibited and may be unlawful. If you are not the intended recipient, or the person responsible for delivering to the intended recipient, you should not read, copy, disclose or otherwise use this message. If you have received this email in error, please delete it, and advise the sender immediately.
I am working on my first updatable query.  I have checked the updatable box for the column but, that column is grayed out and will not allow me to update it.  Does anyone know what I may be doing wrong?
Millicent
Check the Updatability checkbox at the right top of the screen.
*Amélie Pelletier*
*Analyste Programmeur / Program analyst*
[image: cid:image001.jpg@01CD5525.2091A820]
*230, Boulevard Nilus-Leclerc*
*L'Islet, Québec (Canada)*
*G0R 2C0*
*Téléphone: 418-247-3986 ext. 2390*
*Fax: 418-247-7925*
*amelie.pelletier@... <brigitte.savoie@...>*
*P* Est-ce nécessaire d’imprimer ce message?
*Please consider the environment before printing this email**.*
*De :* vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
*Envoyé :* 18 septembre 2014 10:59
*À :* vantage@yahoogroups.com
*Objet :* [Vantage] Updatable Query
Millicent
I have checked updatable on the first screen “General tab”.
I have checked updatable on the “Update tab” for the column I want to update.
Sorry, I don’t see another one.
Sent: Thursday, September 18, 2014 11:00 AM
Subject: RE: [Vantage] Updatable Query
*Amélie Pelletier*
*G0R 2C0*
*Fax: 418-247-7925*
Millicent
Hi,
You’re in the list then? In your BAQ, did you do the BPM update processing?
Then, in the list, you must double click on the line you want to update to
do so. It’s only in the BAQ creation you have to do this. In the menu you
‘ll put it, it will work only in clicking the column.
*Amélie Pelletier*
*G0R 2C0*
*Fax: 418-247-7925*
*Envoyé :* 18 septembre 2014 11:10
*Objet :* RE: [Vantage] Updatable Query
update.
<vantage@yahoogroups.com>]
*Amélie Pelletier*
*G0R 2C0*
*Fax: 418-247-7925*
Millicent
I am in BAQ Designer on the analyze and test screen. If I double click it gives me an error message. Should I be on another screen to update the information?
Sent: Thursday, September 18, 2014 11:12 AM
Hi,
*Amélie Pelletier*
*G0R 2C0*
*Fax: 418-247-7925*
update.
*Amélie Pelletier*
*G0R 2C0*
*Fax: 418-247-7925*
Millicent
Carol
What is the error message you are getting?
Carol
