Update baq to close PO release
I created an updateable BAQ to update PO release due date - works fine. I added the field PORel_OpenRelease to be updated (so I can close all the PO releases left open) - I get list - (it does list all the open PO releases) - I double click and uncheck the OPEN REL check box - when I hit UPDATE I get the following error
Severity: Exception, Table: PORel, Field: , RowID: 81735df9-c6d4-422c-93df-9a6e4bdd1269, Text: Release is closed
Query returned 1 row(s).
However, if I then double click the line again - and select the box (to put tick mark back on) - then update - it processes.
What am I missing?
Are you checking the status of the change between saving?
