You need to update the first release in BPM. When you update the line you
can look at the RowMod. If it is an A, then enable a post process that then
goes in at the newly created release level and modify the value there.
For some reason anywhere there is a first release it doesn't go through the
normal methods of create new release in Orders, PO's, etc.
litzer1
Sent: Friday, March 26, 2010 10:42 AM
Subject: [Vantage] Update field on Order Release
I have setup a field on the Order Header called "Ship From", which we are
going too use to indicate what Plant (we are multi-plant but not in Vantage)
a Part will be shipping from. In order to give us the flexibility at the
Release level I have setup this field on the Order Release Tab also. Then
the Sales Person can select on the Order Header where it is being shipped
from and if needed can change this on the Release level if a different line
or release is being shipped from a different Plant.
I want the same functionality as Ship Via whereas the Ship From on the
Release gets populate with the same value from Order Header when the Order
Line is saved for the first time. I am able to set the customization up
where is a sunsequent release is created it will copy the value from order
Header but I cannot get the first release to populate after the Order Line
I am using the EpiViewNotification to update the subsequent releases and
have tried various other Events to try to make the first release get
populated with no success.
Scott
litzer1
Scott
