Update of global record is not allowed
We are in 10.400.1.22 and when on Process Security Maintenance after adding a new Group under Selected Groups/Users and trying to save it, we get the error “Update of global record is not allowed.”
Has anyone else experienced this problem? I have included some screenshots:
SCR 194370 addressed in 10.1.400.23+/10.1.500.8+.
Thank you Nathan.
I’ve got a Public Cloud system we’re trying to set up security for, and the Allow Access and Disallow Access for all users buttons are greyed out, so everyone has access to everything. When I try to DMT changes in (using either Security Groups or UserIDs), I get the “update of global record is not allowed” message. This is 10.2.500.10. What setting am I missing?
In Help, under Getting Started there’s a section for Cloud Users. The TL;DR is that you have to create a Security ID for each Company. Again, probably remnants of MT :poop:.
In Help, search for Modify Menu Security under ERP Cloud Guide. If you have a lot, you may want to use DMT.
Mark W.
You may want to put this in its own topic as it’s not related to the error above.
Also noted here: https://epicweb.epicor.com/doc/Docs/EpicorERP_PublicCloudGuide_102500.pdf
This is a good document for the Cloud Users anyway…
You ROCK. I’ll create the new topic and mark it as SOLVED. Thanks!
