Update Qty in Service Connect Epicor 905
Hi Rob
Got it working - thanks
Regards
Adrian Lauchlan
Inceptum Projects Ltd
Mob 07852 270968
On 21 Nov 2011, at 18:24, Rob Bucek <rbucek@...> wrote:
> Maybe I should have been more specific..quantity of what, in what form?
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> [Description: cid:1.234354861@...]<http://www.dsmfg.com/>
> (Click the logo to view our site)<http://www.dsmfg.com/>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Adrian Lauchlan
> Sent: Monday, November 21, 2011 12:21 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Update Qty in Service Connect Epicor 905
> Sorry - Parts
> Regards
> Adrian Lauchlan
> mobile 07852 270968
> You can now call me on my Skype Number
> skype +44 (0)208 123 5065
> The information in this email including any attachments is intended only for the exclusive use of the person or body it is addressed to. It may contain confidential and privileged material that may be subject to legal privilege. It may not be disclosed, disseminated, re-transmitted or distributed without the permission of the sender. If you have received this email in error, please delete it from your system and contact the sender. Please note that it is the recipient's responsibility to check for viruses and Inceptum Projects Ltd will not be held responsible for any damages arising from virus infections.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Rob Bucek
> Sent: 21 November 2011 17:55
> Subject: Re: [Vantage] Update Qty in Service Connect Epicor 905
> Quantity of what?
> Sent from my Verizon Wireless 4GLTE Phone
> -----Original message-----
> From: "adrian.lauchlan" <adrianlauchlan@...<mailto:adrianlauchlan%40googlemail.com> <mailto:adrianlauchlan%40googlemail.com> >
> To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> " <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> >
> Sent: Mon, Nov 21, 2011 16:17:47 GMT+00:00
> Subject: [Vantage] Update Qty in Service Connect Epicor 905
> Hi
> Has anyone created a workflow to Adjust Qty in Service connect for Epicor 905 - can't get mine to work
Hi
Quantity of what?
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Hi
Sorry - Parts
Regards
Adrian Lauchlan
mobile 07852 270968
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
Quantity of what?
From: "adrian.lauchlan" <adrianlauchlan@... <mailto:adrianlauchlan%40googlemail.com> >
To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> " <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Hi
Rob Bucek
FAX: (715)284-4084
Sorry - Parts
Regards
Adrian Lauchlan
mobile 07852 270968
Quantity of what?
Hi
Adrian,
I wrote a workflow that does this for a client, as I recall, it was one of
the more straight-forward ones that I wrote. Are you getting any error
messages, or is it simply not running?
A couple things to check:
1. Do a trace when you do it manually, and check the fields over
pretty closely compared to your document trace in Service Connect.
2. Sometimes you have to set the RowMod manually. Typically, that's
with a row being added/updated on a table, and the quantity adjust is a
little different. However, you may want to hardcode an "A" or "U" in there,
just to test it out.
3. Are you sure your company/plant settings are correct? If you're
multicompany, and the user that you have attached to the web services is in
a different company, and you're not explicitly setting the company, you may
have issues. However, that would likely throw an error at you that would
point to that.
4. Did you check the app server logs? Sometimes, there's an error
message there that may be helpful.
Hope that helps,
Kevin Simon
SimsTrak Consulting, LLC
adrian.lauchlan
Sent: Monday, November 21, 2011 11:17 AM
Hi
Hi Kevin
Got it working - thanks for your help
Regards
Adrian Lauchlan
Mob 07852 270968
On 21 Nov 2011, at 19:34, "Kevin Simon" <simstrak@...> wrote:
> Adrian,
> point to that.
> Hope that helps,
> Kevin Simon
> adrian.lauchlan
> Hi
