Yes to all.
No production against the job or any operation.
Guess I will not beat my head against the wall on this one and start trying to hold the data in some other tables that there may be less rules to how the records can be updated.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Silly question, but said job is
> Open, not Released not Engineered right?
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Mon, Nov 12, 2012 at 12:38 PM, mmcwilliams22 <mmcwilliams22@...>wrote:
> > That did not work either Rob, but thanks for the suggestion.
> > --- In vantage@yahoogroups.com, Rob Bucek <rbucek@> wrote:
> > > Try
> > > JobOperAdapt.JobOperSearchData.Tables("JobOper").Rows(0).BeginEdit()
> > > JobOperAdapt.JobOperSearchData.Tables("JobOper").Rows(0)("Number01") =
> > decHrs
> > > JobOperAdapt.JobOperSearchData.Tables("JobOper").Rows(0).EndEdit()
> > > Rob Bucek
> > > Production Control Manager
> > > PH: (715) 284-5376 ext 311
> > > Mobile: (715)896-4832
> > > FAX: (715)284-4084
> > > [cid:1.234354861@]<http://www.dsmfg.com/>
> > > (Click the logo to view our site)<http://www.dsmfg.com/>
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> > Behalf Of mmcwilliams22
> > > Sent: Monday, November 12, 2012 8:53 AM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Re: Update UD field on JobOper from Job Entry
> > > For testing I just have it tied to a button click..
> > > Dim decHrs As Decimal = 25.25
> > > Dim JobOperAdapt As JobOperSearchAdapter = New
> > JobOperSearchAdapter(JobEntryForm)
> > > JobOperAdapt.BOConnect()
> > > Dim jobNum As String = Jobhead.DataView(JobHead.Row)("JobNum")
> > > Dim assemblySeq As String = "0"
> > > Dim oprSeq As String = "10"
> > > Dim JobOper As Boolean = JobOperAdapt.GetByID(jobNum, assemblySeq,
> > oprSeq)
> > decHrs
> > > JobOperAdapt.Update()
> > > JobOperAdapt.Dispose()
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Jose
> > Gomez <jose@> wrote:
> > > > When are you doing your update? Show your code? Also make sure you are
> > not
> > > > in JobTracker been there done that.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > On Fri, Nov 9, 2012 at 5:15 PM, mmcwilliams22 <mmcwilliams22@>wrote:
> > > > > Is there any other properties of the adapter I need to set to be
> > able to
> > > > > update a UD field on JobOper. I am getting an Update Not allowed
> > error when
> > > > > executing my code.
> > > > [Non-text portions of this message have been removed]
