Hi Steven -
Thanks on this. As per my earlier post, I thought that I had it nailed with Customization, but it's still not quite right.
I may turn to your BPM idea if I can't tweak it ----
Thanks for the tip -
Laraine
Laraine
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> I have the same situation. I use a BPM to copy the original reqdate to a UD field. The BPM checks to see if the UD field has anything in it, if it doesn't it copies the reqdate to it. This way, only the original reqdate is saved and never overwritten.
> ÂÂ
> Steven G.
> From: laraines422 <laraines422@...>
> To: vantage@yahoogroups.com
> Sent: Wednesday, May 30, 2012 2:26 PM
> Subject: [Vantage] Update UD Field ONCE Only
> ÂÂ
> Hi All,
> I give up! I've searched through this site and EpicWeb, and I'm coming up blank for ideas.
> Here is my challenge:
> 1. Our OrderRel.ReqDate is constantly changed by our Users. That's OK, because our Production can't seem to commit to firm completion dates (but that's a different issue).
> 2. Again, it's OK that the ReqDate is changed, but we want to track the FIRST/INITIAL "ReqDate" - we want a static date to measure our performance. (We do use the "dynamic" ReqDate for other reporting.)
> 3. No problem so far with this - I'm populating OrderRel.Date01 with the OrderRel.ReqDate with a Form Event in Customization.
> The question is: how do I lock down OrderRel.Date01 after it's initially populated? Obviously - with only the code in #3 applied, Date01 changes as ReqDate is changed - which defeats the purpose (I don't want the User to change this field). Do I add code in the customization, to look at the Date01 field to see if it's already populated? I also thought about a Row Rule - but the logic didn't seem to be appropriate to allow to populate on the first pass and then not to allow to populate for anything later. Or do I create a BPM at Sales Order Update? It seems like the former would be simpler (I did putz around with this), but I'm OK with a BPM, too - my code writing for both is equally weak and suspect. :-)
> If it matters - we're on Vantage 8.03.407c...
> Thanks in advance -
> Laraine
