Updateable Dashboard - Customization Problem
Hello all,
I am on 9.05.701 and have found that I cannot customize an updateable dashboard.  I created a simple dashboard to update the OrderHed.RequestDate.  The dashboard works fine and updates fine.  I wanted to add a new Tracker View to the dashboard so I could add a button to perform a custom action.  I can add the tracker view and the button, but as soon as I add any custom code to the script editor, my problems start.  Upon deployment I get the error shown below.  Any help would be greatly appreciated.  Also I stripped all the custom code down to just a button click event that calls a message box that says Hello World.
Jason
Error Detail
Constructor on type 'TestNameSpace.V_SI_MFG038_1ViewDetailPanel1CodeBehind' not found.
Stack Trace
at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Reflection.Assembly.CreateInstance(String typeName, Boolean ignoreCase, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at Epicor.Mfg.UI.App.SI_OKTODEL.V_SI_MFG038_1ViewDetailPanel1.V_SI_MFG038_1ViewDetailPanel1_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.UserControl.OnLoad(EventArgs e)
at Epicor.Mfg.UI.FrameWork.EpiBasePanel.OnLoad(EventArgs e)
at System.Windows.Forms.UserControl.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.ControlCollection.Add(Control value)
at Epicor.Mfg.UI.FrameWork.UIApp.EpiHostForm.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at Epicor.Mfg.UI.FrameWork.EpiForm.WndProc(Message& message)
