Updateable Dashboard
I have created an updateable BAQ with three UD comment fields on order lines (Purchasing Comments, Production Comments, and Quality Comments). I now want to make these fields accessible to users so they can view and update the comments directly.
Could you advise on the best way to publish the updateable BAQ so that users can easily access and update the records?
Through a dashboard. Look into how to deploy dashboards in general and then how to make the dashboard “updatable.” I believe it’s a flag on the grid/BAQ datasource.
can you guide me through the steps, i did one using application studio but it wont show the edit and update part
The steps to deploy a dashboard? Or the steps to make it updatable?
make the Dashboard updateable, the BAQ is already ticked updateable.
“Now that you have created an updatable BAQ, you can use it in a dashboard. You create custom dashboards in Application Studio using the Basic Application Wizard . Learn how to use this wizard by reviewing the Working with Basic Application Wizard help article.”
That’s from this article: Creating Updatable BAQs – Kinetic 2024.2
Thank you, i knew how the application wizard works, but just didnt go ahead and tick the updateable columns again. Thank you very much. It Worked
Would you please consider either making a more specific post with screenshots/steps that show how to do it and marking that as the solution or marking my post as a viable answer if you believe it was good enough to guide the next person who has your same problem to the answer?
sorry for late response, it worked thank you
