Updated to 9.05.701 - now error
It was a while between the times messing with it and I had started a 700c DB but had data issues so I started over and created a blank one. I thought I had everything set up to log in with Manager but I am questioning myself now.Â
Â
I did hear from Epicor and they gave me some steps to try but it was working. So I went back to my instructions and started over...I am stuck on the Restore Schema Holders.....it fails there.
Â
Â
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Monday, March 11, 2013 6:22 PM
Subject: RE: [Vantage] Updated to 9.05.701 - now error
Â
I would start by setting the log to verbose and starting only the main app server. The messages from the Application are not going to help much.
Check the ports and logins in the system agent if the db starts okay.
You say the current db is blank. Was it running 700C? Wouldn't it need the basics of company, users, etc to run?
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of faepigrl
Sent: Monday, March 11, 2013 4:57 PM
To: mailto:vantage%40yahoogroups.com
Subject: [Vantage] Updated to 9.05.701 - now error
We have a test environment on 9.05.700c and I recently applied all the patches to update to 9.05.701. I can launch the application but get an error. It is almost like it can't find the DB. The current DB is blank and no conversions needed to run. I don't know if I missed a step or if it is somethine else. I do have a ticket in with Epicor.
Error:
Unable to launch program'Epicor.Mfg.UI.SysMonitorEntry.dll'
Record not found
Error Condition: The server application has returned an error (7243)
(7211)
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Error:
Record not found
(7211)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of faepigrl
Error:
Record not found
(7211)
