Updating a Field based on other field
This was perfect for what I just needed.
I wanted to provide an RMACloseDate field, and Vantage doesn't keep track of that (at least not in 8.03.405).
So I did this:
Private Sub RMAHead_BeforeFieldChange(ByVal sender As object, ByVal args As DataColumnChangeEventArgs) Handles RMAHead_Column.ColumnChanging
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Dim edv As EpiDataView = CType(oTrans.EpiDataViews("RMAHead"), EpiDataView)
Select Case args.Column.ColumnName
'//Since this is a boolean field, we can look at the current value and decide what to do.
Case "OpenRMA"
if edv.dataView(edv.Row)("OpenRMA") = False then
'MessageBox.Show("Opening")
edv.dataView(edv.Row)("Date03") = DBNull.Value
else
'MessageBox.Show("Closing")
edv.dataView(edv.Row)("Date03") = DateTime.Now
end if
Case Else
End Select
End Sub
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of efyf_1999
Sent: Thursday, April 29, 2010 1:26 PM
Subject: [Vantage] Re: Updating a Field based on other field
Thanks to Sean i was able to get it work
Seams i had to close the screen and reopen for it to work
Ephraim
--- In vantage@yahoogroups.com, "efyf_1999" <effgroups@...> wrote:
> Thanks Sean,
> I tried it and it still didnt work.
> At what time will the other field be updated? when i change the value? what will happen if there is a value already?
> here is the code i did
> Private Sub ProjectTask_AfterFieldChange(ByVal sender As object, ByVal args As DataColumnChangeEventArgs) Handles ProjectTask_Column.ColumnChanged
> Dim EDV As EpiDataView = CType(oTrans.EpiDataViews("ProjectTask"), EpiDataView)
> Case "Number03"
> EDV.dataView(EDV.Row)("Duration") = EDV.dataView(EDV.Row)("Number03")
> Case Else
> End Select
> End Sub
> Please help me
> Thanks
> Ephraim
> --- In vantage@yahoogroups.com, "Sean McDaniel" <smcdaniel@> wrote:
> > When you are in the form you can go into the wizards and hook into the
> > on-change event of the added field.
> > When this event triggers you can update your other field (go into tools,
> > object explorer, click on the data objects tab to find your field that
> > you want to change)
> > Would typically be something like this in the form customization...
> > Private Sub BAQReportParam_AfterFieldChange(ByVal sender As object,
> > BAQReportParam_Column.ColumnChanged
> > Case "Character02"
> > Dim [edvVarName] As
> > EpiDataView = CType(oTrans.EpiDataViews("ReportParam"), EpiDataView)
> > [edvVarName].dataView([edvVarName].Row)("Character01") =
> > [edvVarName].dataView([edvVarName].Row)("Character02")
> > Case Else
> > End Select
> > End Sub
> > Of efyf_1999
> > Sent: Thursday, April 29, 2010 10:47 AM
> > Subject: [Vantage] Updating a Field based on other field
> > Hi all,
> > I'm going to ask a very simple thing but dont laugh at me since im not
> > yet so familiar with vista nd everything i know i learned on my own.
> > I added a custom numeric field in the Project task and now i want to
> > update the duration field with that new field multiplied by 0.5 whenever
> > a user changes that field what are my uptions?
> > Thanks for the help
Hi all,
I'm going to ask a very simple thing but dont laugh at me since im not yet so familiar with vista nd everything i know i learned on my own.
I added a custom numeric field in the Project task and now i want to update the duration field with that new field multiplied by 0.5 whenever a user changes that field what are my uptions?
Thanks for the help
you want to change)
Case "Character02"
Dim [edvVarName] As
Case Else
End Select
End Sub
Of efyf_1999
Hi all,
Thanks for the help
Thanks Sean,
Case "Number03"
Case Else
End Select
End Sub
Please help me
Ephraim
> you want to change)
> Case "Character02"
> Dim [edvVarName] As
> Case Else
> End Select
> End Sub
> Of efyf_1999
> Hi all,
> Thanks for the help
Ephraim
> Thanks Sean,
> Case "Number03"
> Case Else
> End Select
> End Sub
> Please help me
> Thanks
> Ephraim
> > you want to change)
> > Case "Character02"
> > Dim [edvVarName] As
> > Case Else
> > End Select
> > End Sub
> > Of efyf_1999
> > Hi all,
> > Thanks for the help
