Cool... Thanks Ned, I'll give that a try on my next go-around (probably next week).
As it turns out, in ONE of the log files, there is a single line that says something about running out of memory. Although this box has 24G RAM, the HD is pretty small and only has a tiny swap file... I'll find a larger HD and try it again.
Ernie Lowell
Diba Industries
Ernie Lowell
Diba Industries
--- In vantage@yahoogroups.com, Ned <TechnoBabbly@...> wrote:
> I find it to be faster, just because it's using less layers of
> communication.
> Scripts are DB dependant, and are located in
> \Epicor905\32\ClientServer\db\SQL or
> \Epicor905\32\ClientServer\db\SQLUnicode.
> The scripts are named with the program level names, ex: 905-600DF.SQL
> So if you are on 9.05.605 then you will need to run 905-700DF.SQL
> There are some other scripts in there, but in general that's all that needs
> to be done, I have found fewer errors and the SQL reporting of any errors is
> much more clear.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> too_much_hg
> Sent: Monday, April 15, 2013 4:28 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Updating my test server to 9.05.702
> Ned,
> That is very interesting ... 2 questions:
> 1. Is this significantly faster ? How much faster ?
> 2. Where are these SQL scripts ? I would like to try this method.
> Thanks,
> Neil
> --- In vantage@yahoogroups.com, Ned <TechnoBabbly@> wrote:
> > Generally, for SQL systems, I don't use the schema change tool, I run
> > the SQL scripts one by one directly on the SQL DB through the SQL
> > Server Management Suite.
> > I have not run into any problems other than getting an error about a
> > unique primary key while running the conversions after schema changes.
> > Behalf Of Elizabeth
> > Sent: Monday, April 15, 2013 11:49 AM
> > Subject: [Vantage] Updating my test server to 9.05.702
> > An interesting experience. In previous update scenarios (and I've done
> > a few), the Schema Change portion of the program went pretty much
> > without any hitches. Start it, go have a nice leisurely dinner on the
> > company tab, and come back to see it finished.
> > Ahh, the good old days.
> > This time, each piece of the Schema Change gave an error, and then
> > exited, saying check the log. Well, the logs didn't say anything about
> > errors, so I would run Schema Change again... and each time it made it
> > through the NEXT piece before erroring again. I'm starting at
> > 9.04.507, so when I began it the first time it said "Database Level
> > 9.04.500" and "Program Level 9.05.702". After the first error (and
> > color returning to my face) when I ran it a second time it said,
> > "Database level 9.05.100" and still "Program level 9.05.702". After
> > each time the "Database Level" went up a notch, so the program was
> > working properly(?), but taking its own error messages a little too
> seriously.
> > It's on the last one now (applying 905-700DF.SQL), so I'll let you
> > know how it finishes.
> > Anyone else give this a shot yet?
> > Ernie Lowell
> > Diba Industries
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
