Updating OrderDtl/OrderRel NeedBy and ReqDate in 4GL BPM
Hi Brian,
I had to do this same thing where the needby and request date fields needed to be changed at order entry time or when an order was later changed. What I did was set up a pre-process BPM for OrderHed and a post-process BPM for the OrderDtl and OrderRel table to update my date fields.
David Pfiester
NuStep, Inc.
734-769-3939 x150
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> For reasons that you don't really want to understand, I have a need to do a mass update (swap really) of a bunch of dates in the open sales orders in one of my companies. Basically all open sales orders needs to have all of their NeedBy and ReqDate dates swapped.
> This looked doable in a BPM as I could trigger the update via checkbox change in OrderHed and having someone tick through the set of open orders wouldn't be a big deal.
> However, it turns out that if I trigger this off of the update of OrderHed.Checkbox01, only ttOrderHed has any data (ttOrderDtl and ttOrderRel seem to be empty of rows, despite the fact that in the trace I see the full dataset).
> If I try to iterate through OrderDtl and OrderRel and change data, I run into the OpenEdge licensing issue (you can't modify data). I haven't applied the new license to my production environment, but I could.
> My question is twofold:
> 1. Am I missing something? In the client trace I see the full dataset, but if I iterate over ttOrderDtl/ttOrderRel, I don't see any data in my for each statement (just for the header), however if I change the temp-tables to their actual counterparts I get the data I expect in my appserver log. I assumed that since the full dataset in the trace contains the entire SalesOrderDataSet that the temp-tables would also contain the entire thing.
> Here's my code, just looking for data:
> for each ttOrderHed where ttOrderHed.RowMod = 'U'.
> message "SwapShipDateandNeedByDate: Processing Order " + string(ttOrderHed.OrderNum).
> /* OrderDtl Block */
> for each ttOrderDtl where ttOrderDtl.Company = ttOrderHed.Company and ttOrderDtl.OrderNum = ttOrderHed.OrderNum and ttOrderDtl.OpenLine = True.
> message "Processing OrderDtl " + string(ttOrderDtl.OrderLine).
> define variable curOrderDtlNeedByDate as Date no-undo.
> define variable curOrderDtlReqDate as Date no-undo.
> curOrderDtlNeedByDate = ttOrderDtl.NeedByDate.
> curOrderDtlReqDate = ttOrderDtl.RequestDate.
> /* OrderRel Block */
> for each ttOrderRel where ttOrderRel.Company = ttOrderDtl.Company and ttOrderRel.OrderNum = ttOrderDtl.OrderNum and ttOrderRel.OrderLine = ttOrderDtl.OrderLine and ttOrderRel.OpenRelease = True.
> message "Processing OrderRel " + string(ttOrderRel.OrderRelNum).
> define variable curOrderRelNeedByDate as Date no-undo.
> define variable curOrderRelReqDate as Date no-undo.
> curOrderRelNeedByDate = ttOrderRel.NeedByDate.
> curOrderRelReqDate = ttOrderRel.ReqDate.
> end.
> end.
> end.
> 2. Can I safely modify the ReqDate (Ship By Date) in a 4GL action like this?
> I don't want to have to break out ServiceConnect, as this would be a tedious (for me at least) workflow to write for a one-time deal. I've not had to deal with searching and iterating over search results in sub-workflows.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
end.
end.
end.
-bws
