Yes, that is the actual path. Taken from the mfgsys803 appserver properties dialog under Agent/General in the Progress Explorer tool. We are running a Progress database on Centos 5.8 64bit.
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> Is that your ACTUAL propath or did you just remove the "c:\" stuff for
> whatever reason?
> Your directories look correct, but you should be using the full path.
> i.e. c:\epicor\mfgsys803\server\
> On Fri, May 4, 2012 at 7:13 PM, jharrington65 <jharrington@...>wrote:
> > I commented my code out leaving only the PublishInfoMsg line like you
> > suggested and still, I receive the same error message. I am logged in as
> > myself as I am setup in User Maintenance as a Security Manager. Oddly
> > enough, when I log in as Manager and drill down into Method Directives to
> > the Actions window, the "Advanced..." button one clicks on to bring up the
> > source code window is greyed out.
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > Out of curiosity comment you the rest of your BPM, and just leave the
> > > Publish Info MSG, also make sure you are logged in as manager and that
> > you
> > > have read/write access to the mfgysys903\Server and all its children.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > *checkout my new blog <http://www.usdoingstuff.com> *
> > > *T: 904.469.1524 mobile
> > > E: jose@
> > > http://www.josecgomez.com
> > > <http://www.linkedin.com/in/josecgomez> <
> > http://www.facebook.com/josegomez>
> > > <http://www.google.com/profiles/jose.gomez> <
> > http://www.twitter.com/joc85>
> > > <http://www.josecgomez.com/professional-resume/>
> > > <http://www.josecgomez.com/feed/>
> > > *Quis custodiet ipsos custodes?*
> > > On Fri, May 4, 2012 at 4:53 PM, Jose Gomez <jose@> wrote:
> > > > Its Probably your Pro-path in your server.. O boy... do you know how to
> > > > get that?
> > > > If so paste it here.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > <http://www.josecgomez.com/professional-resume/> <
> > > > On Fri, May 4, 2012 at 3:52 PM, Rodzewicz, Greg <
> > > > grodzewicz@> wrote:
> > > >> James,
> > > >> This is right where mine is so this is not the problem either.
> > > >> Thanks,
> > > >> Greg Rodzewicz
> > > >> Developer
> > > >> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> > Behalf
> > > >> Of jharrington65
> > > >> Sent: Friday, May 04, 2012 3:45 PM
> > > >> To: vantage@yahoogroups.com
> > > >> Subject: [Vantage] Re: Updating PartLot table from Receipt Entry
> > > >> PublishInfoMsg.i is indeed located in the lib folder. The lib folder
> > > >> resides under \epicor\mfgsys803\Server\
> > > >> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>,
> > > >> "Rodzewicz, Greg" <grodzewicz@<mailto:grodzewicz@>> wrote:
> > > >> > Not really a silly question I should have thought to ask this.
> > James?
> > > >> > Thanks,
> > > >> > Greg Rodzewicz
> > > >> > Developer
> > > >> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > >> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
> > > >> Behalf Of bw2868bond
> > > >> > Sent: Friday, May 04, 2012 2:00 PM
> > > >> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > >> > Silly questions maybe
> > > >> > Is the lib folder in the correct place?
> > > >> > is PublishInfoMsg.i in the lib folder?
> > > >> ><mailto:vantage%40yahoogroups.com>, "Rodzewicz, Greg" <grodzewicz@
> > > >> > > James,
> > > >> > > I looked at your screen shot and it looks good to me. I do not
> > > >> understand how you are getting the error the way you are getting it.
> > Again
> > > >> the only way I can replicate the error is to remove the slash, but
> > > >> obviously you have the slash in there. Unfortunately this is beyond
> > me.
> > > >> Hopefully someone else that knows better can chime in and help you
> > out.
> > > >> > > Thanks,
> > > >> > > Greg Rodzewicz
> > > >> > > Developer
> > > >> ><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> > > >> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>]
> > On
> > > >> Behalf Of jharrington65
> > > >> > > Sent: Friday, May 04, 2012 10:37 AM
> > ><mailto:
> > > >> > > Hi Greg,
> > > >> > > Thanks for your suggestion. I've done both copy & paste and
> > manually
> > > >> typing in the line, but I still receive the same message. This time I
> > > >> uploaded a screenshot of the source code window and the exact message
> > I
> > > >> receive so that you can see for yourself. Perhaps I am missing
> > something
> > > >> you can spot in the screenshot. It's in the Photos section and
> > entitled
> > > >> "Code error msg"
> > > >> > > Thanks!
> > > >> > > James
> > > >> > > > James,
> > > >> > > > I am on 8.03.409c and use this code regularly with no issue's
> > so it
> > > >> is not versioning. I do have to agree with Jose that your error
> > message
> > > >> points to a missing slash. The only way I was able to replicate the
> > error
> > > >> was to remove the slash. Stranger things than a copy/paste not working
> > > >> perfectly have been known to happen. Please double check your code and
> > > >> possibly even just re-type the offending line to make sure the editor
> > isn't
> > > >> seeing anything wonky from the copy/paste.
> > > >> > > > Thanks,
> > > >> > > > Greg Rodzewicz
> > > >> > > > Developer
> > ><mailto:
> > > >> vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
> > Behalf
> > > >> Of jharrington65
> > > >> > > > Sent: Thursday, May 03, 2012 10:08 PM
> > > >> > > > Yes, I copied and pasted it directly from your text.
> > > >> ><mailto:vantage%40yahoogroups.com>, Jose Gomez <jose@<mailto:jose@>>
> > > >> wrote:
> > > >> > > > > Are you using lib\Publishinfo? your error makes it look like
> > you
> > > >> are
> > > >> > > > > missing the slash
> > > >> > > > > {lib\PublishInfoMsg.i &InfoMsg = "'Fire! ' "}.
> > > >> > > > > ?? Let me know
> > > >> > > > > Thanks
> > > >> > > > > *Jose C Gomez*
> > > >> > > > > *Software Engineer*
> > > >> > > > > E: jose@
> > > >> > > > > On Thu, May 3, 2012 at 5:03 PM, jharrington65 <jharrington@
> > > >> <mailto:jharrington@>>wrote:
> > > >> > > > > > Jose,
> > > >> > > > > > First, I'd like to say thanks for taking the time to
> > address my
> > > >> issue. I
> > > >> > > > > > can certainly see from scouring the many threads on here in
> > > >> search of
> > > >> > > > > > resolutions that you are an invaluable contributor to a lot
> > of
> > > >> the
> > > >> > > > > > inquiries in this forum. I'm sure a speak for most when I
> > say
> > > >> it is truly
> > > >> > > > > > appreciated.
> > > >> > > > > > I took your advise and removed the no-lock on PartLot. I
> > also
> > > >> added the
> > > >> > > > > > msg line you gave me. However, after copying it in and
> > clicking
> > > >> on the OK
> > > >> > > > > > button, I receive the following message:
> > > >> > > > > > ** "libPublishInfoMsg.i" was not found. (293)
> > > >> > > > > > ** Could not understand line. (193)
> > > >> > > > > > I failed to mention in my original post that we are
> > currently
> > > >> on Vantage
> > > >> > > > > > version 8.03.409c if that makes a difference.
> > > >> > > > > > Thanks again,
> > > >> > > > > > James
> > > >> ><mailto:vantage%40yahoogroups.com>, Jose Gomez <jose@> wrote:
> > > >> > > > > > > See if its firing put this in your code
> > > >> > > > > > > To make sure your query is excecuting properly, if you
> > don't
> > > >> get a
> > > >> > > > > > message
> > > >> > > > > > > Box with the word Fire then something is up!
> > > >> > > > > > > Also you have No-Lock on partLot, but you are updating it.
> > > >> you may want
> > > >> > > > > > to
> > > >> > > > > > > remove that.
> > > >> > > > > > > *Jose C Gomez*
> > > >> > > > > > > *Software Engineer*
> > > >> > > > > > > E: jose@
> > > >> > > > > > > On Wed, May 2, 2012 at 10:11 AM, jharrington65
> > <jharrington@
> > > >> >wrote:
> > > >> > > > > > > > I have created a user defined field in the "Stock" tab
> > of
> > > >> the Receipt
> > > >> > > > > > > > Entry screen. This text field is associated with
> > > >> {RcvDtl.ShortChar01}.
> > > >> > > > > > > > I have also created a user defined field in the Lot
> > Entry
> > > >> screen and
> > > >> > > > > > it is
> > > >> > > > > > > > associated with {PartLot.ShortChar01}.
> > > >> > > > > > > > When receiving stock into the Receive Entry screen, I
> > want
> > > >> the
> > > >> > > > > > > > RcvDtl.ShortChar01 field to populate the
> > > >> PartLot.ShortChar01 field
> > > >> > > > > > based on
> > > >> > > > > > > > the Lot Number in the Receipt Entry "Stock" tab.
> > > >> > > > > > > > I have managed to add the following code to the
> > > >> Receipt.Update method
> > > >> > > > > > > > directive under Post-Processing tab in the action
> > section
> > > >> under the
> > > >> > > > > > part
> > > >> > > > > > > > that should be executed before the designed actions:
> > > >> > > > > > > > For each ttRcvDtl where (ttRcvDtl.RowMod = 'A' or
> > > >> ttRcvDtl.RowMod =
> > > >> > > > > > 'U')
> > > >> > > > > > > > no-lock.
> > > >> > > > > > > > find PartLot where (PartLot.Company = ttRcvDtl.Company
> > and
> > > >> > > > > > PartLot.PartNum
> > > >> > > > > > > > = ttRcvDtl.PartNum and PartLot.LotNum = ttRcvDtl.LotNum)
> > > >> no-lock.
> > > >> > > > > > > > if available PartLot then do:
> > > >> > > > > > > > Run lib\UpdateTableBuffer.p(input BUFFER
> > > >> > > > > > > > PartLot:HANDLE,'ShortChar01',ttRcvDtl.ShortChar01).
> > > >> > > > > > > > end.
> > > >> > > > > > > > end.
> > > >> > > > > > > > I get no errors when saving the directive or validating
> > it,
> > > >> nor do I
> > > >> > > > > > > > receive any errors when receiving stock into the Receipt
> > > >> Entry screen.
> > > >> > > > > > I've
> > > >> > > > > > > > checked the Rcvdtl table and the ShortChar01 field is
> > > >> definitely being
> > > >> > > > > > > > populated with the data, it just isn't making it over
> > the
> > > >> the PartLot
> > > >> > > > > > > > table. What am I missing? Thanks for anything that can
> > > >> point me in the
> > > >> > > > > > > > right direction.
> > > >> > > > > > > > James Harrington
> > > >> > > > > > > > IT/ERP Administrator
> > > >> > > > > > > > HEATCON, Inc.
> > > >> > > > > > > > Seattle, WA
> > > >> > > > > > > > (206) 575-1333
> > > >> > > > > > > [Non-text portions of this message have been removed]
> > > >> > > > ________________________________
> > > >> > > > CONFIDENTIALITY NOTICE - This e-mail transmission and any
> > > >> accompanying documents contain information belonging to the sender
> > which
> > > >> may be confidential and legally privileged. This information is
> > intended
> > > >> only for the use of the person to whom this e-mail transmission was
> > sent as
> > > >> indicated above. If you are not the intended recipient, any
> > disclosure,
> > > >> copying, distribution, or action taken in reliance on the contents of
> > the
> > > >> information contained in this transmission is strictly prohibited. Any
> > > >> commodities, technology or software exported in this e-mail are being
> > > >> exported from the United States in accordance with export
> > administration
> > > >> regulations, diversion contrary to USA law is prohibited.
> > which
> > intended
> > sent as
> > disclosure,
> > the
> > administration
> > accompanying
> > > >> documents contain information belonging to the sender which may be
> > > >> confidential and legally privileged. This information is intended
> > only for
> > > >> the use of the person to whom this e-mail transmission was sent as
> > disclosure,
> > the
> > administration
> > > >> CONFIDENTIALITY NOTICE - This e-mail transmission and any accompanying
> > only for
> > disclosure,
> > the
> > administration
> *John Driggers*
> *High End Dev, System Design, Profit Drinking*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
