Updating ShipDtl through code
Anyone else having problem updating OurInventoryShipQty field through code? I realized there is another field called SellingInventoryShipQty that has the same value. Do we need to update both fields? I have tried both and the Update() method passes but the value does not get updated. Here is a snapshot of my code:
I already have a row on index 0 that has quantities for both job and inventory but the line below does not readjust the quantities to 1 and it does not throw any exception either.
Thanks!
Ship from Inventory will also require a warehouse and bin to be specified. Ship from job will require a job number.
Yes and those values are all in place. Lets say there is already a shipment record with inventory qty of 10 and job qty of 5 and the warehouse/bin as well as job number are in the record.
When I call that code to just update the quantity, it does not update it and also I do not receive any error message!
There are probably going to be calls that make the changes. follow the trace. I’m pretty sure there is an OnChangeQty method or something like that.
Also, it doesn’t look like you are setting a row mod.
edit:
GetQtyInfo is the call that happens when you make that change in the UI
Yeah I did all that as well. Including the GetQtyInfo…
Something is fishy here, when the quantity in inventory or job are high like 10, 15, then it works, the reduction works, but if there is like 2 left, I cannot deduct 1!!
I haven’t encountered anything like it before.
Ever figure this out? Have the exact same issue. Can’t seem to get it to set a value to 1 for OurInventoryShipQty. Missing something. Unsure what.
I may have figured it out on my end. Unsure if you solved it as well.
I added this field and it worked:
DisplayInvQty
Also make sure these are in there as well:
OurInventoryShipQty
SellingShipmentQty
I think I did try DisplayInvQty and didn’t work. I gave up and had to find a different approach.
I will give your idea a try. Updating all the three fields, maybe it will work! Thanks!
So far that is working for me without issue.
