Updating SQL tables in Vantage 8.03.403D
So far we haven't had a problems. Make sure not to leave any Null values though. Vista/Vantage does not like that and you'll get funny errors. As far as how it works, Progress is just a passthru on a SQL install. You are basically taking the middle man out.
----- Original Message ----
Sent: Tuesday, January 8, 2008 7:27:45 AM
Subject: [Vantage] Updating SQL tables in Vantage 8.03.403D
Hello All,
We have developed a Post Dated Cheques module to be used with Vantage. Our Vantage installation and the PDC module is using MS SQL as the back end. As of now the data flow is only from Vantage to PDC module. We would like to know if there are any issues if we update or insert into SQL tables in Vanatage with validated values. Will it have any issue with Progress which is in between Vantage and MS SQL? Any suggestions will be much appreciated.
We would also like to know very briefly about the role of Progress when MS SQL is used with Vantage. Is Progress storing any data in this case?
Farshad.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Hello All,
Farshad.
