Updating Vendor Tracker
I don't think so. The tracker is a different base form (App.SupplierTracker.VendorForm) than the entry form (App.VendorEntry.VendorForm), so unless you want to make a read-only version of the customized vendor entry form and deploy that as the tracker instead of using the normal tracker, you have to customize the tracker field-by-field to match the customized entry screen.
We have started customizing some on our entry screens and I can't figure out how to update the trackers. Is there an easy way to make the tracker reflect the changes made in the Vendor Entry screen without adding each field separately?
