thanks Ned for the answer
Can 9.04 work with progress 1.02a or do i need to have both progress
running?
running?
On Fri, Nov 23, 2012 at 6:48 PM, Ned <TechnoBabbly@...> wrote:
> Yes, they can both exist, they can both run at the same time, however,
> there
> will be a problem accessing the admin service since both will use the same
> port, it can be changed with a registry edit, I believe the instructions
> are
> in the documentation area somewhere.
> -----Original Message-----
> Of
> Ephraim Feldman
> Sent: Friday, November 23, 2012 1:18 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Upgrade 9.04.507A to 9.05.701 on same server
> Hi All
> We are in the process to upgrade to 9.05.701 We use Progress 64bit
> I installed it a while back on a test server and did all the testing and
> modifications we needed.
> Now i want to install it on my existing epicor server where my 9.04
> resides.
> What are the implications of the? can oe101c and 102a reside on the same
> server? can both versions of epicor co-exist on the same server?
> Any help would be appreciated
> Ephraim
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
