Upgrade from 305 to 400 need help!
Go to the following:
ftp://ftpmpls.epicor.com
Log in with your Epicor user id and password.
Navigate to the Vantage/Dump_Load Folder.
Open up the appropriate folder and download the .zip file.
Extract the file to an appropriate location (preferably on your Vantage Server).
There is a document that gives detailed instructions on how to perform the Dump and Load. If you have ODBC security on your database you will also need the ODBC kit that goes with your version. That will be in the Vantage/ODBC folder. It also gives detailed instructions.
If you have any difficulty or don't quite understand the instructions I won't mind you notifying me directly. I do both of these on a regular basis. In fact, I have my procedures down to less than an hour to do a complete dump and load and set the ODBC authority for a 4 ½ GB database. It is not bad once you have done it a few times. In fact, it is something that should be done on a regular basis. It is sort of like doing a defrag on a hard drive. A little more complex but not bad once you understand it.
Ensure you download the correct version.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Edward F. Fox, Jr.
Sent: Tuesday, July 29, 2008 7:08 AM
Subject: RE: [Vantage] Re: Upgrade from 305 to 400 need help!
I think you need to get the utility kit from Epicor.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-0162 Fax 401-596-1050
www.maxsonautomatic.com
_____
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Charlie Wilson
Sent: Tuesday, July 29, 2008 7:18 AM
Can you guide me to a document that tells me how to do the dump and load. I
have never don't this before.
~Charlie
_____
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
Charles Carden
Sent: Monday, July 28, 2008 5:22 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Charlie,
It appears you may have a corrupt index. I would do a dump and load on 305
and then attempt the upgrade.
Behalf Of Charlie Wilson
Sent: Monday, July 28, 2008 12:13 PM
Sure Did.
~Charlie
_____
<mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]
On Behalf Of
Edward F. Fox, Jr.
Sent: Monday, July 28, 2008 1:09 PM
Have you run proutil mfgsys -C truncate bi ?
Controller
_____
Behalf Of
Charlie Wilson
Sent: Monday, July 28, 2008 12:57 PM
The conversion starts running and gives the following error "SYSTEM ERROR:
Index SortOrdText in original text for recid 263522 could not be deleted.
(1422)" I assume it is trying to drop an index and can't can some one help?
~Charlie
From: TechnoBabbly [mailto:TechnoBabbly@ <mailto:TechnoBabbly%40gmail.com>
gmail.com]
Sent: Monday, July 28, 2008 11:48 AM
To: 'Charlie Wilson'
You need to open the admin tools and run conversions after the schema
change.
<mailto:foamdesigncsw%40yahoo.com> yahoo.com]
Sent: Monday, July 28, 2008 10:49 AM
To: 'TechnoBabbly'
Alright so I think I have all the upgrades to the actual server made but now
I am trying to log in. and I get the fallowing error. "The system needs
upgraded, please check with your administrator."
I have installed the three pieces that you need to have before you install
the client 3.0 .net, Crystal Runtime, and the web service. But I still get
this error message. Any Suggestions?
~Charlie
gmail.com]
Sent: Monday, July 28, 2008 10:11 AM
Not to worry, most non-employees can't troubleshoot that kind of stuff since
most non-employees don't do that many installations to know what comes up
for
possible problems and errors while doing them, and what is a quick fix for
someone who works there can be a 3-4 hour task for someone who doesn't.
Sent: Monday, July 28, 2008 10:06 AM
To: 'TechnoBabbly'
Never mind I got it working... I was using the wrong version of the progress
explorer tool so the Db wasn't started. Once I used the right tool I was
able to get the proper DB started and it took right off.. Thanks for all the
help. I'll be a pro when the next noob joins the group and I will help them
out...
~Charlie
gmail.com]
Sent: Monday, July 28, 2008 9:27 AM
Also, if you have both 10.0B and 10.1B on the same machine, make sure that
you
have the Schema holder tool pointing to the right version folder of
progress.
The EPICOR\OE101B instead of EPICOR\OE100B
Sent: Monday, July 28, 2008 8:18 AM
To: 'TechnoBabbly'
So I'm back to the schema Change step and I am getting the following error.
"Database c:\epicor\mfgsys803\db\mfgsys is a 32-bit dbkey database. (13893)
This codebase cannot connect to an open 32-bit dbkey database (13894)
I confirmed that my admin service is stopped. I even set it to manual and
restarted the server just to make sure.
I checked over the command line and it seems to be pointing to the correct
location for files per the instructions below. Are there any other
suggestions for this error?
~Charlie
gmail.com]
Sent: Saturday, July 26, 2008 11:19 AM
To: foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com> yahoo.com
Charlie, a few things...
1- The install problem you initially had while on the domain, try this for a
solution:
Summary: Windows cannot access the specified device, path, or file
Book: Support Solutions
Page: 9054MPS
Windows cannot access the specified device, path, or file Version 8.03.x
This error occurs when trying to launch an executable file, typically the
MfgSys
Server Install exe from the install DVD. Page number 8743MPS also deals with
this issue. If the steps in 8743MPS do not resolve the issue try the steps
below. These instructions are the solution that Microsoft provide.
FROM MICROSOFT:
Remove the software restriction policy, and also delete the keys in the
registry
for the policy.
These are located at: [HKEY_CURRENT_USER or
HKEY_LOCAL_MACHINE]\SOFTWARE\Policies\Microsoft\Windows\Safer
Anything that is listed under there is a restriction for an executable. In
this
test case, the customer deleted any keys there and the installation went
fine.
2- Are you a progress installation or an MS SQL installation? If you are SQL
make sure you UNCHECK the box for Unicode during the installation unless you
are
already Unicode, and if you are then you will know it.
3- The installation program doesn't correctly create the command line in
your
Icons for Admin tools and schema change tools, you will need to edit them to
point to the correct locations of your mfgsys.ini and *.pf files, otherwise
you
will get errors.
4- When running things like conversions and schema changes, it is best to
have
your appservers turned off, and if you are an MS SQL installation, I would
recommend manually running the schema changes in SQL instead of using the
tool.
No virus found in this incoming message.
Checked by AVG - http://www.avg <http://www.avg <http://www.avg
<http://www.avg <http://www.avg.com> com> com> com>
com
Version: 8.0.138 / Virus Database: 270.5.6/1574 - Release Date: 7/25/2008
4:27 PM
com
Version: 8.0.138 / Virus Database: 270.5.6/1577 - Release Date: 7/28/2008
6:55 AM
com
6:55 AM
com
6:55 AM
Checked by AVG - http://www.avg <http://www.avg <http://www.avg.com> com>
com
6:55 AM
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or
proprietary information, and may be used only by the person or entity to
which it is addressed. If the reader of this e-mail is not the intended
recipient or his or her authorized agent, the reader is hereby notified that
any dissemination, distribution or copying of this e-mail is prohibited. If
you have received this e-mail in error, please notify the sender by replying
to this message and delete this e-mail immediately.
Checked by AVG - http://www.avg <http://www.avg.com> com
6:55 AM
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
I'm working on upgrading a test server from 8.03.305 to 8.03.40X i'm am fallowing the instructions as stated in the manual. But when i go to run the file that is the actual server upgrade i get an error that states. "Windows can not access the specified, device, path, or file. You may not have appropriate permissions to access the item." well seeing as that i am a domain admin i dont believe this is actually a permissions issue. I'm running this file off the DVD they send you in the mail to do the upgrade.
Any help any one.
Whenever I come across that error, I copy the relevent file(s) onto
the server I actually working on, then right-click, select Properties
and click "Unblock". That clears it. Don't know if you can do this
with the files still on the DVD.
Nigel.
--- In vantage@yahoogroups.com, Charlie Wilson <foamdesigncsw@...>
> Any help any one.
I'm must be blind but i am not seeing this "unblock" option you are talking about. I did copy the files off the DVD to the local machine.
~Charlie
Â
[mailto:vantage@yahoogroups.com] On Behalf Of Nigel Kerley
Sent: Thursday, July 24, 2008 10:32 AM
Subject: [Vantage] Re: Upgrade from 305 to 400 need help!
Â
Nigel.
> Any help any one.
I had the exact same thing.
I even did the unblock suggestion, but to no avail.
Even though I was logged into the console as the domain admin, it would still only work if I right-clicked on the setup.exe and select RUN AS and re-enter the credentials of domain\administrator with the correct password.
I have no idea why, but this was it, every time. It also did not matter what server this was on, test or live.
Carey
To: vantage@yahoogroups.comFrom: nigel.kerley@...: Thu, 24 Jul 2008 14:31:52 +0000Subject: [Vantage] Re: Upgrade from 305 to 400 need help!
Whenever I come across that error, I copy the relevent file(s) onto the server I actually working on, then right-click, select Properties and click "Unblock". That clears it. Don't know if you can do this with the files still on the DVD.Nigel.--- In vantage@yahoogroups.com, Charlie Wilson <foamdesigncsw@...> wrote:>> I'm working on upgrading a test server from 8.03.305 to 8.03.40X i'm am fallowing the instructions as stated in the manual. But when i go to run the file that is the actual server upgrade i get an error that states. "Windows can not access the specified, device, path, or file. You may not have appropriate permissions to access the item." well seeing as that i am a domain admin i dont believe this is actually a permissions issue. I'm running this file off the DVD they send you in the mail to do the upgrade. > > Any help any one. > > > [Non-text portions of this message have been removed]>
_________________________________________________________________
Time for vacation? WIN what you need- enter now!
http://www.gowindowslive.com/summergiveaway/?ocid=tag_jlyhm
That did not work either. Any more suggestions?
~Charlie
Â
[mailto:vantage@yahoogroups.com] On Behalf Of Carey S
Sent: Thursday, July 24, 2008 11:18 AM
Â
Carey
nigel.kerley@...:
need help!
Login as the local Admin. If the OS is Windows 2000, Vista, or 2008
Domain Admin is not the same as the local admin. If that doesn't work
it's possible you have a corrupt file somewhere. It could also be a
program or service running interfering with the install, did you reboot
prior to install? Do you have anti-virus running?
Of Charlie Wilson
Sent: Thursday, July 24, 2008 10:36 AM
To: Vantage Gorup
~Charlie
Behalf Of Carey S
still
re-enter
what
Carey
To: vantage@yahoogroups.comFrom <mailto:vantage%40yahoogroups.comFrom> :
nigel.kerley@... <mailto:nigel.kerley%40johnhinde.comDate>
to 400
need help!
server
<mailto:vantage%40yahoogroups.com> ,
is the
access
permissions
the DVD
Internal Virus Database is out of date.
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.5.0/1558 - Release Date:
7/17/2008 9:56 AM
I logged into a local admin account and didn't really get anywhere. Does it
make a difference that I am doing this from a Remote desktop?
Another factor in all this is that our app server is a VM.
~Charlie.
_____
Jim Mediger
Sent: Thursday, July 24, 2008 1:01 PM
Behalf
Of Charlie Wilson
To: Vantage Gorup
~Charlie
Behalf Of Carey S
still
re-enter
what
Carey
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.comFrom> .comFrom
nigel.kerley@ <mailto:nigel.kerley%40johnhinde.comDate> johnhinde.comDate
to 400
need help!
server
is the
access
permissions
the DVD
http://www.gowindow
<http://www.gowindowslive.com/summergiveaway/?ocid=tag_jlyhm>
7/17/2008 9:56 AM
Version: 8.0.138 / Virus Database: 270.5.5/1570 - Release Date: 7/24/2008
6:59 AM
I ran into this with one of my machines a few months ago. I am trying to give you the right answer but I can't remember for sure. It had something to do with a local security policy getting set inadvertently. If I remember right execute the local security policy under control panel. If you have anything under software restriction policies, just right click Software Restriction Policies and select Delete Software Restriction Policies. I believe if you have anything in there it will keep the Vantage setup from running because it is being recognized as a 16 bit program.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charlie Wilson
Sent: Thursday, July 24, 2008 9:20 AM
Subject: [Vantage] Upgrade from 305 to 400 need help!
Any help any one.
DISCLAIMER:
NO software restriction policies defined. Still not working. Anything else I
should look for?
_____
Charles Carden
Sent: Thursday, July 24, 2008 4:14 PM
Subject: RE: [Vantage] Upgrade from 305 to 400 need help!
Any help any one.
DISCLAIMER:
6:59 AM
Two more things to try.
1. Open and command prompt window and run the Setup.exe program. Don't run the .exe that brings up the install menu just the one that installs the mfgsys. I don't have the DVD handy so I can't tell you exactly which one it is. This will tell you if windows explorer has any software execution restrictions.
2. Uninstall the Internet Explorer Enhanced Security Configuration
Try number 1 first. If that works you are set to go. If you ever use the server to access the internet (not advisable) then you most definitely want to do number 2 above or it will be a real pain to browse for anything.
Sent: Friday, July 25, 2008 5:59 AM
should look for?
_____
Charles Carden
Any help any one.
DISCLAIMER:
6:59 AM
DISCLAIMER:
IE Enhanced Security Uninstalled - Check
Command Prompt - Check
Execute MFGSYS803.exe - Houston we have a problem. "Access Denied"
Any other suggestions?
~Charlie
_____
Charles Carden
Sent: Friday, July 25, 2008 7:29 AM
restrictions.
should look for?
_____
On Behalf Of
Charles Carden
Any help any one.
DISCLAIMER:
6:59 AM
DISCLAIMER:
6:59 AM
I think you have already tried copying the data locally and ensuring the program is unblocked. Right?
Is your local (intranet) domain the same as your internet domain? If so then the system may not be able to detect your local domain correctly and is restricting program installation. If that is the case you may have to open internet explorer and manually add your domain as an intranet domain. If you are unsure how to do this let me know.
Sent: Friday, July 25, 2008 6:43 AM
~Charlie
_____
Charles Carden
restrictions.
should look for?
_____
On Behalf Of
Charles Carden
Any help any one.
DISCLAIMER:
6:59 AM
DISCLAIMER:
6:59 AM
DISCLAIMER:
Yes please guide me on how to do this.
~Charlie
_____
Charles Carden
Sent: Friday, July 25, 2008 8:18 AM
~Charlie
_____
On Behalf Of
Charles Carden
restrictions.
should look for?
_____
On Behalf Of
Charles Carden
Any help any one.
DISCLAIMER:
com
6:59 AM
DISCLAIMER:
6:59 AM
DISCLAIMER:
6:59 AM
Open Internet Explorer.
Select Tools/Internet Options
Click the Security Tab
Select Local Intranet and click the Sites button
Uncheck the Automatically detect intranet network
Check all 3 boxes listed
Click the advanced tab
Add your local domain to the list of websites, e.g. thisdomain.com
Sent: Friday, July 25, 2008 7:58 AM
~Charlie
_____
Charles Carden
~Charlie
_____
On Behalf Of
Charles Carden
restrictions.
should look for?
_____
On Behalf Of
Charles Carden
Any help any one.
DISCLAIMER:
com
6:59 AM
DISCLAIMER:
6:59 AM
DISCLAIMER:
6:59 AM
DISCLAIMER:
Good Morning Everyone,
I am confused! Maybe someone else has run into this. I am trying to
find out when the user clicks on the counter sale button on the order
entry screen. So far my bmp looks like:
SalesOrder.ChangeCounterSale
Pre-Processing
Enabled - checked
Prevent endless loops - checked
Conditions: the ttOrderhed.CounterSale field has been changed from
false to true.
Actions: show information message based on the test template
When the user goes to click on the field nothing happens and when the
reclick on it (to change it from checked to unchecked) nothing happens.
So here is the part I really do not understand: If I change the
Conditions line to:
Conditions: the ttOrderhed.CounterSale field has been changed from true
to false.
Then I get the message box to show up when I remove the check mark from
the Counter Sales box (just the opposite of what I want). So why can't
I just swap the conditions (like I was originally trying to do) and have
it work?
Thanks in Advance!
Dale Kalsow | Information Technologies Director | Determan Brownie,
Inc.
Work: 763-502-9689 | Fax: 763-571-1789 | Mail:
dale.r.kalsow@... <mailto:dale.r.kalsow@...>
"Ambition is the path to success. Persistence is the vehicle you arrive
in."
Electronic Privacy Notice. This e-mail, and any attachments, contains
information that is, or may be, covered by the Electronic Communications
Privacy Act, 18 U.S.C. 2510-2521, and is also confidential and
proprietary in nature. If you are not the intended recipient, please be
advised that you are legally prohibited from retaining, using, copying,
distributing, or otherwise disclosing this information in any manner.
Instead, please reply to the sender that you have received this
communication in error, and then immediately delete it. Thank you in
advance for your cooperation.
Does the original "false to true" test work after the check box has been toggle to true and back to false once? If so it may be the initial state of the field was null not false. Just a wild guess...I'm a ways away from BPMs yet...but easy to check.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dale R. Kalsow
Sent: Friday, July 25, 2008 8:13 AM
Subject: [Vantage] BPM Confusion!
Pre-Processing
Enabled - checked
false to true.
Conditions line to:
to false.
it work?
Thanks in Advance!
Inc.
dale.r.kalsow@...<mailto:dale.r.kalsow%40determan.com> <mailto:dale.r.kalsow@...<mailto:dale.r.kalsow%40determan.com>>
in."
Done still not work even after a restart.
~Charlie
_____
Charles Carden
Sent: Friday, July 25, 2008 9:11 AM
~Charlie
_____
On Behalf Of
Charles Carden
~Charlie
_____
On Behalf Of
Charles Carden
restrictions.
should look for?
_____
On Behalf Of
Charles Carden
Any help any one.
DISCLAIMER:
com
6:59 AM
DISCLAIMER:
com
6:59 AM
DISCLAIMER:
6:59 AM
DISCLAIMER:
6:59 AM
No it does not work even after the check mark is in the box. I have
also tried it from null to true and that does not catch it either.
Has anyone ever triggered a bpm from a check box. How did you implement
that. It should be the same.
Thanks!
Dale
Of Todd Caughey
Sent: Friday, July 25, 2008 8:21 AM
Subject: RE: [Vantage] BPM Confusion!
-Todd C.
Pre-Processing
Enabled - checked
false to true.
Conditions line to:
to false.
it work?
Thanks in Advance!
Inc.
dale.r.kalsow@... <mailto:dale.r.kalsow%40determan.com>
in."
Charlie,
I am out of ideas. Do you know is there are any domain policies in affect that would prohibit the installation? We looked at local policies but not domain. That is the last idea that I have.
Sent: Friday, July 25, 2008 9:04 AM
~Charlie
_____
Charles Carden
~Charlie
_____
On Behalf Of
Charles Carden
~Charlie
_____
On Behalf Of
Charles Carden
restrictions.
should look for?
_____
On Behalf Of
Charles Carden
Any help any one.
DISCLAIMER:
com
6:59 AM
DISCLAIMER:
com
6:59 AM
DISCLAIMER:
6:59 AM
DISCLAIMER:
6:59 AM
DISCLAIMER:
