Upgrade from 8.00.811 to 8.03 problems
I run the schemachange, and it drops out half way through the process
with no error. I guess I will just re-install it over the old stuff,
or delete the 803 install and re-try it again.
--- In vantage@yahoogroups.com, "crypticsphere" <james.hill@...> wrote:
> Appreciate the help Gerard, I was beginning to edit the path earlier,
> I didn't have it going completely to the right spot, it's very
> different from the path from the 8.00.811 path. My schema change is
> working correctly now.
> Thanks,
> James
> --- In vantage@yahoogroups.com, "Gerard Wadman" <gwadman@> wrote:
> > I got the same error, I had to run the properties for the schema
change
> > shortcut and fix the path.
> > My MfgSys803 install was on the E drive so the and that is where my
> > mfgsys803\server\config\mfgsys.pf file was copied.
> > I edited the Target path to point to the correct file and all worked
> > fine.
> > Below is how my current target looks.
> > E:\epicor\oe100b\bin\prowin32.exe -pf
> > E:\epicor\mfgsys803\Server\config\mfgsys.pf -ininame
> > C:\CLIENT~1\config\mfgsys.ini -rx -p applydf.w
> > Gerard M Wadman
> > Sr. Network Systems Engineer
> > Scandius BioMedical Inc.
> > 11A Beaver Brook Road
> > Littleton, MA 01460
> > 978/486-4088 x 124
> > 978/486-4108 (fax)
> > http://www.scandius.com/
> > This e-mail is for the use of the intended recipient(s) only. If you
> > have received this e-mail in error, please notify the sender
immediately
> > and then delete it. If you are not the intended recipient, you
must not
> > use, disclose or distribute this e-mail without the author's prior
> > permission. We have taken precautions to minimize the risk of
> > transmitting software viruses, but we advise you to carry out your own
> > virus checks on any attachment to this message. We do not accept
> > liability for any loss or damage caused by software viruses
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
Behalf
> > Of crypticsphere
> > Sent: Monday, June 04, 2007 2:20 PM
> > Subject: [Vantage] Upgrade from 8.00.811 to 8.03 problems
> > Ok, I got the upgrade to 8.00.811 done fine, then I started working on
> > the 8 to 8.03, I backed up the db, then i ran the utilities like it
> > wanted me too, moved it to the new db folder under mfgsys803\db did
> > the utils on there, had no errors. Typed exit, went to changeschema in
> > my newly installed folder on my desktop and double clicked it and i
> > get a error **Unab;e tp open parameter file
> > c:\client~1\config\mfgsys.pf, errno 2. (1247)
> > Any help is appreciated. thanks
Just a thought, but have you tried to repair the db?
--SF
I got the same error, I had to run the properties for the schema change
fine.
Gerard M Wadman
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
have received this e-mail in error, please notify the sender immediately
and then delete it. If you are not the intended recipient, you must not
Of crypticsphere
James
> fine.
> Gerard M Wadman
> Littleton, MA 01460
> 978/486-4088 x 124
> 978/486-4108 (fax)
> Of crypticsphere
