Upgrade from 9.05.607 to 9.05.702 !Need help!
Pete:
I just installed the client including the admin tools on my 64bit app server and they ran. I had seen posts that it was able to do so in 702.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Pete Horner
Sent: Saturday, July 13, 2013 11:05 AM
Subject: Re: [Vantage] Re: Upgrade from 9.05.607 to 9.05.702 !!!!!!Need help!!!!!!!!
Hello Tom, you mention that your consultant was able to run the admin tools (64 bit) on your server, vs running 32 bit admin tools from a client.
Do you know how this is done ? I am struggling with running conversions and would like to run directly on the server if possible.
any help would be greatly appreciated.
thank you,
Pete Horner
IT Manager
Prince Mfg
248.830.9204
From: Tom Grynovich <tgrynovich@...<mailto:tgrynovich%40yahoo.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Thursday, June 6, 2013 11:25 AM
Drew that is the norm as slow as it may be
Sent: Thursday, June 6, 2013 10:13 AM
We tried to do our conversion on a 32 bit admin workstation on a friday evening by monday morning it was far from done. We had to abort and our consultant found a method to run the task on our (epicor says you cannot do this on a 64 bit server) new server rather than through a 32 bit admin workstation. We are running a 7 year conversion next thursday since we ran a 3 year conversion 2 weeks ago that was successful.
To: mailto:vantage%40yahoogroups.com
Sent: Sunday, May 26, 2013 8:41 AM
Subject: [Vantage] Re: Upgrade from 9.05.607 to 9.05.702 !!!!!!Need help!!!!!!!!
I have been looking at task manager for a day now. It is moving,but at a very slow pace. What concerns me is that it shows it is doing the same process the last time I was able to see. The conversion window is blacked out and says not responding, but again the task manager jumps to 1 from 0 every 10-20 secs. Is that normal?
--- In mailto:vantage%40yahoogroups.com, Jose Gomez <jose@...<mailto:jose@...>> wrote:
> Look in task manager if your process is using cpu and oscillating some what
> it's probably just working
> On May 25, 2013 8:14 PM, "Drew" <ahsalloum@...<mailto:ahsalloum@...>> wrote:
> > I don't remember it taking this long. I am not sure why.
> > All apps are off, but the 905 database is running. Should it be not
> > running?
> > --- In mailto:vantage%40yahoogroups.com, "Ned" <TechnoBabbly@> wrote:
> > > Make sure you have no Appservers also connected to the DB, I have run
> > into
> > > that problem before and had it stall things out for a really long time.
> > > What happened when you ran this in your test environment first?
> > > -----Original Message-----
> > > From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On
> > Behalf Of
> > > Drew
> > > Sent: Saturday, May 25, 2013 6:33 PM
> > > Subject: [Vantage] Upgrade from 9.05.607 to 9.05.702 !!!!!!Need
> > help!!!!!!!!
> > > Hello folks,
> > > I am currently upgrading from 9.05.607 to 9.05.702 this weekend and I
> > > am sitting still at the moment and wanted to ask if I have an issue or is
> > > this normal. I have upgraded my Open Edge and SQL Service Pack to 702 and
> > > now I am running the necessary Conversions Using the Epicor Admin Tool.
> > It
> > > has been running for about 10 hours now and actually stuck on one
> > > process(Message: Updating CashHead CashBook values from BankTran) for
> > about
> > > 4 hours. I am checking to see if it is still running from task manager
> > and
> > > it seems to be moving, but very very little. It jumps from 0 to 1 every
> > > 10-20 seconds or so for activity. I am getting pretty nervous now and
> > > Epicor Support just goes to voicemail and no one will return my call.
> > > Has anyone had the same conversion length of time and is this normal or
> > is
> > > there something wrong? Any experience you can share would help me feel
> > less
> > > nervous.
> > > Thanks,
> > > Andrew
> > > 678-522-9779
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> > > already linked your email address to a yahoo id to enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Hello folks,
I am currently upgrading from 9.05.607 to 9.05.702 this weekend and I am sitting still at the moment and wanted to ask if I have an issue or is this normal. I have upgraded my Open Edge and SQL Service Pack to 702 and now I am running the necessary Conversions Using the Epicor Admin Tool. It has been running for about 10 hours now and actually stuck on one process(Message: Updating CashHead CashBook values from BankTran) for about 4 hours. I am checking to see if it is still running from task manager and it seems to be moving, but very very little. It jumps from 0 to 1 every 10-20 seconds or so for activity. I am getting pretty nervous now and Epicor Support just goes to voicemail and no one will return my call.
Has anyone had the same conversion length of time and is this normal or is there something wrong? Any experience you can share would help me feel less nervous.
Andrew
678-522-9779
Make sure you have no Appservers also connected to the DB, I have run into
Drew
Subject: [Vantage] Upgrade from 9.05.607 to 9.05.702 !!!!!!Need help!!!!!!!!
Hello folks,
nervous.
Andrew
678-522-9779
All apps are off, but the 905 database is running. Should it be not running?
> Drew
> Hello folks,
> nervous.
> Thanks,
> Andrew
> 678-522-9779
> running?
> into
> Behalf Of
> > Drew
> help!!!!!!!!
> > Hello folks,
> It
> about
> and
> is
> less
> > nervous.
> > Thanks,
> > Andrew
> > 678-522-9779
> have
> > running?
> > into
> > Behalf Of
> > > Drew
> > help!!!!!!!!
> > > Hello folks,
> > It
> > about
> > and
> > is
> > less
> > > nervous.
> > > Thanks,
> > > Andrew
> > > 678-522-9779
> > have
Sounds like something went wrong, I would let that one just run, and
possibly take a the backup you made before starting and throwing it on your
test box and see how it goes, or put it in test on the same server and let
it run there.
Drew
Sent: Sunday, May 26, 2013 9:41 AM
help!!!!!!!!
> what it's probably just working On May 25, 2013 8:14 PM, "Drew"
> > running?
> > > run
> > into
time.
> > Behalf Of
> > > Drew
> > help!!!!!!!!
> > > Hello folks,
> > It
> > > for
> > about
> > > manager
> > and
> > > every
call.
> > > normal or
> > is
> > > feel
> > less
> > > nervous.
> > > Thanks,
> > > Andrew
> > > 678-522-9779
> > > must
> > have
> > > Builder and Crystal Reports and other 'goodies', please goto:
Â
> > running?
> > into
> > Behalf Of
> > > Drew
> > help!!!!!!!!
> > > Hello folks,
> > It
> > about
> > and
> > is
> > less
> > > nervous.
> > > Thanks,
> > > Andrew
> > > 678-522-9779
> > have
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Â
Â
> > running?
> > into
> > Behalf Of
> > > Drew
> > help!!!!!!!!
> > > Hello folks,
> > It
> > about
> > and
> > is
> > less
> > > nervous.
> > > Thanks,
> > > Andrew
> > > 678-522-9779
> > have
thank you,
Pete Horner
IT Manager
Prince Mfg
248.830.9204
Â
Â
Â
> > running?
> > into
> > Behalf Of
> > > Drew
> > help!!!!!!!!
> > > Hello folks,
> > It
> > about
> > and
> > is
> > less
> > > nervous.
> > > Thanks,
> > > Andrew
> > > 678-522-9779
> > have
