Upgrade to 5.0 - Report Builder Part 2
You may need to apply the two patches (found on the egroups list or from Epicor) called odbcuser.r and userfix.r to your TEST database. The path to the document is here:
http://groups.yahoo.com/group/vantage/files/ODBC/_Vantage%20v5.1/Odbc51.zip
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, May 30, 2002 5:06 PM
Subject: Re: [Vantage] RE: Upgrade to 5.0 - Report Builder Part 2
Thad
You helped me with this same problem last week. Report Builder works fine now that I found the "service" names for the different databases.
BUT, I CAN'T GET ODBC to work for Crystal Reports to anything but the Epic51 LIVE database. I have set up configurations for my test databases in Progress Explorer, using new Port numbers, and added the lines to the SERVICES file in the WINNT\SYSTEM32\DRIVERS\ETC folder. The path to database, names and service names follow the pattern used for the primary database. But the TEST connections fail because of a "string" error. I've removed and reinstalled using different names, different port numbers. Without success.
Any suggestions?
Bob
To: 'vantage@yahoogroups.com'
Sent: Thursday, May 30, 2002 1:39 PM
Subject: RE: [Vantage] RE: Upgrade to 5.0 - Report Builder Part 2
The term "Service" here is referring to the service name you specified when
you installed vantage. If you followed the installation manual verbatim, the
service name for a 5.0 database is EPIC50. For Vantager 4, it's EPICOR, and
for vantage 3, it's vntgserv.
The report builder file references this service name in the database
connections dialog, and it will point to your old database by default as
long as the old DB is on line.
There is a "Prompt Always" setting or something like it that will cause
Builder to prompt you for new connection parameters whenever a report is
opened.
Thaddeus Jacobs
Information Solutions Developer
Kinematic Automation, Inc.
mailto:tjacobs@...
Sent: Thursday, May 30, 2002 11:29 AM
Subject: [Vantage] RE: Upgrade to 5.0 - Report Builder Part 2
How do I check that? I checked "Services" in Control Panel and didn't see
anything that rang a bell....
__________________________
Gary Grenier
Subject: RE: Upgrade to 5.0 - Report Builder Part 2
Make sure to check the service as well. If you are using the service to
your current live database versus your converted database, more than likely
it is still looking at your live data.
Rick Lane
Intelligent Systems Integration, Inc.
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. If the reader of this message is not the intended recipient, you
are hereby notified that you have received this message in error and that
any review, dissemination, distribution or copying of this message
including any attachments is strictly prohibited. If you received this in
error, please contact the sender and delete the material from any computer.
Yahoo! Groups Sponsor
ADVERTISEMENT
ADVERTISEMENT
OK, so I will wait. I still, however, would like to "fix" ONE so I know
what I am doing. The very first one I tried is a report that I put in the
Vantage menu via Custom Report Link. I get a message stating that the
field, "shipqty" no longer exists in the InvcDtl table, then it quits. I
opened Report Builder to see what I could do. My first job, of course was
to change the database connection to look at the new DB. Well, it LOOKS
like it is connecting to the new DB. If I click on Report/Database
Connections/Show Details, I see a path to the new DB. However, the
supposedly nonexistent shipqty field is there. I do an "insert" and find
it still in the list. I MUST be missing something here. It sure seems
like it is still looking at the 4.0 DB. Many of you have been through this
(modifying your 4.0 reports for 5.0).... I seek your wisdom.
Gary
I didn't. If your stopover is only a brief one - less than a day - I
wouldn't, especially if none of the "double-check the database" reports
that
you run (Inventory/WIP Recon, etc.) are in Report Builder.
Subject: [Vantage] Upgrade to 5.0 - Report Builder
On a test server, I have upgraded from 4.0 to 5.0. My question is this:
Is it necessary that I take the time to fix all the broken report builder
reports before I upgrade to 5.1, or is that just a huge waste of time
because I'll have to do it again after the second upgrade?
Rick Lane
600 Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
"Helping Business Make Intelligent Use of Technology"
Sent: Wednesday, May 29, 2002 3:53 PM
Subject: [Vantage] Upgrade to 5.0 - Report Builder Part 2
Gary
that
Some field names from 4 to 5 have changed. The shipqty field could be
ourshipqty or sellingshipqty. You have to pick the correct field in report
builder reports in all areas, report fields, calculated fields or aggregate
fields. The same is true for jobshipqty and orderqty. Those quantity
fields now have our or selling in the field name.
Gary
that
ShipQty is now SellingShipQty
Sent: Wednesday, May 29, 2002 2:53 PM
Gary
that
Gary Grenier
Rick Lane
Never mind! I found it. Thanks for your help! Services under Database
Connections, etc...
Gary Grenier
IT Manager
Bell Manufacturing Co.
(207) 784-2961 x245
mailto:ggrenier@...
opened.
Thaddeus Jacobs
mailto:tjacobs@...
Gary Grenier
Rick Lane
Thad
Any suggestions?
Bob
opened.
Thaddeus Jacobs
mailto:tjacobs@...
Gary Grenier
Rick Lane
ADVERTISEMENT
To make a long story short, I don't use ODBC.
I decided after somewhat sucessfully setting up ODBC in a test environment
that using progress exports was the way to go for my particular setup
(Visual Basic 6.0 / Crystal Developer migrating to Visual Studio .NET (which
has Crystal .NET included).
I call progress queries from visual basic applications, and export the
results to XML files which are loaded into RecordSets / DataSets and bound
at run time to List Views and/or crystal reports. Though I thought files on
disk would create a bottleneck, I've discovered performance just as good, or
better than with ODBC, especially with
Takes a bit of programming, but I've developed class modules and include
files that take care of most of the plumbing work, so now all I have to do
is write the progress query, and the user interface code. For each
department I create menu programs that have a list of applicable reports.
For instance, a list of vendors is displayed in a grid, under which is a
couple of date picker fields. Double clicking on a particular vendor
launches the vendor transaction report for that vendor and date range. A
user types in a part number, hits enter, and the latest BOM is printed. More
work for me, time saved for them.
Most of this could potentially be done with ODBC, but I prefer the 4GL
language over SQL for complex data queries. Also factored into my decision
were the potential security risks related to ODBC. I like only having to
deal with one connection to the database, that being the Progress client.
Though I've tried to modularize my code as to make it less of a when we
change database location and directory structure, It's not quite yet in a
form which one could easily adapt to their environment. If enough people
are interested in the code, however, I may consider posting a commented,
configurable version.
Thaddeus Jacobs
mailto:tjacobs@...
Sent: Thursday, May 30, 2002 2:07 PM
Thad
Without success.
Any suggestions?
Bob
when
the
and
opened.
Thaddeus Jacobs
mailto:tjacobs@...
Gary Grenier
likely
Rick Lane
computer.
have
ADVERTISEMENT
Bob, Follow these procedures for 5.1
Steve Hess
I.S. Manager
Electromech Technologies
316-941-0436
Experience "Collaborative Solutioneering @ Pace"
Come Visit Us at Farnborough Air Show, (22-28 July)
Hall 4, Stand B16
Visit www.electromech.com
Sent: Thursday, May 30, 2002 4:07 PM
Thad
Without success.
Any suggestions?
Bob
when
the
and
opened.
Thaddeus Jacobs
mailto:tjacobs@...
Gary Grenier
likely
Rick Lane
computer.
have
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.3508022.1829184/D=egroupweb/S=17050071
83:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1022792870%3eM=22
6014.2032696.3508022.1829184/D=egroupweb/S=1705007183:HM/A=1000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014.2032696.3508022.1829184/D=egroupmai
l/S=1705007183:HM/A=1000239/rand=559915938>
I had the same kind of problems with ODBC, I contacted Epicor Tech Support
and they sent me 2 files, a Word Document and a Zip file. Here they are...
Follow them and see if it helps,
Steve Hess
I.S. Manager
316-941-0436
Hall 4, Stand B16
Thad
Without success.
Any suggestions?
Bob
when
the
and
opened.
Thaddeus Jacobs
mailto:tjacobs@...
Gary Grenier
likely
Rick Lane
computer.
have
ADVERTISEMENT
ADVERTISEMENT
Check out:
For the groups ODBC related postings. I believe the files from Tech Support
are there.
Just a note Steve, attachments can't make it through yahoogroups.
Thad
Sent: Thursday, May 30, 2002 2:48 PM
Importance: High
Steve Hess
I.S. Manager
316-941-0436
Hall 4, Stand B16
Thad
Without success.
Any suggestions?
Bob
when
the
and
opened.
Thaddeus Jacobs
mailto:tjacobs@...
Gary Grenier
likely
Rick Lane
computer.
have
ADVERTISEMENT
ADVERTISEMENT
