Hi All,
I’m in the process of migrating uplifted reports from E9 to E10. When I install the solution it’s super slow, it takes an hour and 15 minutes to attempt to import ~100 custom crystal reports and hits an error(is it possible there is a timeout of some sort), then all subsequent reports fail with the same error. The first error I’m seeing is as follows. Any pointers / suggestions?
An error occurred while updating the entries. See the inner exception for details
"An error occurred while updating the entries. See the inner exception for details.
The INSERT statement conflicted with the FOREIGN KEY constraint “FK_ReportStyle_Report”. The conflict occurred in database “Epicor10Pilot”, table “Ice.Report”, column ‘ReportID’.
The statement has been terminated."
The nitty gritty details are below:
[11/16/2018 10:33:57 AM] Extracting files from CAB.
[11/16/2018 10:33:57 AM] Process started at 11/16/2018 10:33:57 AM by user eddie.
[11/16/2018 10:34:14 AM] Building ‘CUSTOM’ projects.
[11/16/2018 10:34:14 AM] There are 0 projects to build.
[11/16/2018 10:34:14 AM] Processing data definitions…
[11/16/2018 10:34:14 AM] Beginning the import of Report Data Definition definitions…
[11/16/2018 10:34:18 AM] Import was successful for ‘1099’.
[11/16/2018 10:34:36 AM] Import was successful for ‘ApCheck’.
[11/16/2018 10:35:12 AM] Import was successful for ‘APPaymentEdit’.
[11/16/2018 10:35:33 AM] Import was successful for ‘CshREdit’.
[11/16/2018 10:35:38 AM] Import was successful for ‘GLAccSummary’.
[11/16/2018 10:35:38 AM] Import was successful for ‘jobom’.
[11/16/2018 10:37:55 AM] Import was successful for ‘PackSlip’.
[11/16/2018 10:39:53 AM] Import was successful for ‘PartTranRpt’.
[11/16/2018 10:40:06 AM] Import was successful for ‘RcvLabel’.
[11/16/2018 10:40:15 AM] Import was successful for ‘RvJrnReport’.
[11/16/2018 10:41:18 AM] Import was successful for ‘SGMargin’.
[11/16/2018 10:41:41 AM] Import was successful for ‘StkStatus’.
[11/16/2018 10:41:46 AM] Import was successful for ‘TimePhase’.
[11/16/2018 10:41:59 AM] Import was successful for ‘TS-1099’.
[11/16/2018 10:42:17 AM] Import was successful for ‘TS-BOMLstExt’.
[11/16/2018 10:42:45 AM] Import was successful for ‘TS-BOMWhatIf’.
[11/16/2018 10:42:54 AM] Import was successful for ‘TS-CntVar’.
[11/16/2018 10:42:54 AM] Import was successful for ‘TS-CREDITCARDR’.
[11/16/2018 10:42:54 AM] Import was successful for ‘TS-CUSTRETRATE’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-CustSt’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-CUSTSTATS’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-DMRForm’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-EMPEFF’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-ENDOFLIFE’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-EXCESSINV’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-FGLABELS’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-FGLabelsRev’.
[11/16/2018 10:43:42 AM] Import was successful for ‘TS-INVBYPROJECT’.
[11/16/2018 10:44:17 AM] Import was successful for ‘TS-InvUsage’.
[11/16/2018 10:44:17 AM] Import was successful for ‘TS-JOBPICKLIST’.
[11/16/2018 10:44:39 AM] Import was successful for ‘TS-JournalEditL’.
[11/16/2018 10:44:39 AM] Import was successful for ‘TS-MFGPARTREVIE’.
[11/16/2018 10:46:04 AM] Import was successful for ‘TS-MscPack’.
[11/16/2018 10:46:04 AM] Import was successful for ‘TS-PARTLABELS’.
[11/16/2018 10:48:07 AM] Import was successful for ‘TS-PartTranRpt’.
[11/16/2018 10:48:07 AM] Import was successful for ‘TS-PPPARTREVIEW’.
[11/16/2018 10:48:16 AM] Import was successful for ‘TS-PrintTag’.
[11/16/2018 10:49:19 AM] Import was successful for ‘TS-QUOTE’.
[11/16/2018 10:49:52 AM] Import was successful for ‘TS-RcvLabel’.
[11/16/2018 10:49:52 AM] Import was successful for ‘TS-SALESTXREPT’.
[11/16/2018 10:51:01 AM] Import was successful for ‘TS-SGMargin’.
[11/16/2018 10:51:01 AM] Import was successful for ‘TS-ShipStats’.
[11/16/2018 10:51:56 AM] Import was successful for ‘TS-SOPICK’.
[11/16/2018 10:51:56 AM] Import was successful for ‘TS-SuppOnTime’.
[11/16/2018 10:51:56 AM] Import was successful for ‘TS-SupPORev’.
[11/16/2018 10:52:02 AM] Import was successful for ‘TS-TBRPT’.
[11/16/2018 10:52:02 AM] Import was successful for ‘TS-WIPBALANCES’.
[11/16/2018 10:52:31 AM] Import was successful for ‘TSARAgng’.
[11/16/2018 10:53:20 AM] Import was successful for ‘TSAREdit’.
[11/16/2018 10:56:06 AM] Import was successful for ‘TSARForm’.
[11/16/2018 10:58:59 AM] Import was successful for ‘TSARRMAForm’.
[11/16/2018 11:00:03 AM] Import was successful for ‘TSBankRecEdit’.
[11/16/2018 11:00:18 AM] Import was successful for ‘tsBOMListingRpt’.
[11/16/2018 11:00:18 AM] Import was successful for ‘TSFREIGHTAUDIT’.
[11/16/2018 11:01:53 AM] Import was successful for ‘TSJobTra’.
[11/16/2018 11:01:53 AM] Import was successful for ‘TSMFGINVSHEETS’.
[11/16/2018 11:02:13 AM] Import was successful for ‘TSMtlTag’.
[11/16/2018 11:03:12 AM] Import was successful for ‘TSOrderA’.
[11/16/2018 11:05:28 AM] Import was successful for ‘TSPackSl’.
[11/16/2018 11:06:02 AM] Import was successful for ‘TSPOForm’.
[11/16/2018 11:06:02 AM] Import was successful for ‘TSPPREVIEW’.
[11/16/2018 11:06:44 AM] Import was successful for ‘tsRMAForm’.
[11/16/2018 11:07:07 AM] Import was successful for ‘TSSOBacklog’.
[11/16/2018 11:07:59 AM] Import was successful for ‘tsSubCPack’.
[11/16/2018 11:07:59 AM] Import was successful for ‘TSSupPurchases’.
[11/16/2018 11:07:59 AM] Finished importing Report Data Definition definitions.
[11/16/2018 11:07:59 AM] Beginning the import of Report Style definitions…
[11/16/2018 11:08:00 AM] Import was successful for ‘1099_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘1099_1003’.
[11/16/2018 11:08:00 AM] Import was successful for ‘1099_1004’.
[11/16/2018 11:08:00 AM] Import was successful for ‘ApCheck_1001’.
[11/16/2018 11:08:00 AM] Import was successful for ‘APPaymentEdit_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘ARAgng_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘ARAgng_1003’.
[11/16/2018 11:08:00 AM] Import was successful for ‘ARAgng_1004’.
[11/16/2018 11:08:00 AM] Import was successful for ‘AREdit_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘ARForm_1003’.
[11/16/2018 11:08:00 AM] Import was successful for ‘ARForm_1004’.
[11/16/2018 11:08:00 AM] Import was successful for ‘ARForm_1005’.
[11/16/2018 11:08:00 AM] Import was successful for ‘BankReconEdit_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘BOMListingRpt_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘BOMListingRpt_1003’.
[11/16/2018 11:08:00 AM] Import was successful for ‘BOMListingRpt_1004’.
[11/16/2018 11:08:00 AM] Import was successful for ‘BOMListingRpt_1005’.
[11/16/2018 11:08:00 AM] Import was successful for ‘CntVar_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘COA_1001’.
[11/16/2018 11:08:00 AM] Import was successful for ‘CshREdit_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘CustSt_1002’.
[11/16/2018 11:08:00 AM] Import was successful for ‘GLAccSummary_1001’.
[11/16/2018 11:08:01 AM] Import was successful for ‘GLTrialBal_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘InspInvMovmnt_1001’.
[11/16/2018 11:08:01 AM] Import was successful for ‘InvUsage_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘jobom_1001’.
[11/16/2018 11:08:01 AM] Import was successful for ‘JobTrav_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘JobTrav_1003’.
[11/16/2018 11:08:01 AM] Import was successful for ‘JournalEditList_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘MscPack_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘MtlTags_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘MtlTags_1003’.
[11/16/2018 11:08:01 AM] Import was successful for ‘OrderAck_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘OrderAck_1003’.
[11/16/2018 11:08:01 AM] Import was successful for ‘PackSlip_1001’.
[11/16/2018 11:08:01 AM] Import was successful for ‘PackSlip_1004’.
[11/16/2018 11:08:01 AM] Import was successful for ‘PackSlip_1006’.
[11/16/2018 11:08:01 AM] Import was successful for ‘PackSlip_1007’.
[11/16/2018 11:08:01 AM] Import was successful for ‘PackSlip_1008’.
[11/16/2018 11:08:01 AM] Import was successful for ‘PackSlip_1009’.
[11/16/2018 11:08:01 AM] Import was successful for ‘POForm_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘PrintTag_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘QuotForm_1002’.
[11/16/2018 11:08:01 AM] Import was successful for ‘QuotForm_1003’.
[11/16/2018 11:08:02 AM] Import was successful for ‘RcvLabel_1002’.
[11/16/2018 11:08:02 AM] Import was successful for ‘RcvLabel_1003’.
[11/16/2018 11:08:02 AM] Import was successful for ‘ReceiptInvMvmnt_1001’.
[11/16/2018 11:08:02 AM] Import was successful for ‘RMAForm_1001’.
[11/16/2018 11:08:02 AM] Import was successful for ‘RvJrnReport_1002’.
[11/16/2018 11:08:02 AM] Import was successful for ‘SGMargin_1002’.
[11/16/2018 11:08:02 AM] Import was successful for ‘SGMargin_1003’.
[11/16/2018 11:08:02 AM] Import was successful for ‘SOBacklog_1002’.
[11/16/2018 11:08:02 AM] Import was successful for ‘SOPick_1001’.
[11/16/2018 11:08:02 AM] Import was successful for ‘SOPick_1002’.
[11/16/2018 11:08:02 AM] Import was successful for ‘StkStat_1001’.
[11/16/2018 11:08:02 AM] Import was successful for ‘SubCPack_1002’.
[11/16/2018 11:08:02 AM] Import was successful for ‘TimePhase_1002’.
[11/16/2018 11:08:03 AM] An error occurred while updating the entries. See the inner exception for details.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CREDITCARDR_1001’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTRETRATE_1001’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTRETRATE_1002’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTSTATS_1001’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTSTATS_1002’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTSTATS_1003’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTSTATS_1004’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTSTATS_1005’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-CUSTSTATS_1006’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-DMRForm_1001’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-DMRForm_1002’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-EMPEFF_1001’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-ENDOFLIFE_1001’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-EXCESSINV_1001’.
[11/16/2018 11:08:03 AM] Import cancelled or failed for ‘TS-FGLabelsRev_1001’.
[11/16/2018 11:08:04 AM] An error occurred while updating the entries. See the inner exception for details.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-FGLABELS_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-INVBYPROJECT_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-INVBYPROJECT_1002’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-JOBPICKLIST_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-JOBPICKLIST_1002’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-MFGPARTREVIE_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-MFGPARTREVIE_1002’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-PARTLABELS_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-PPPARTREVIEW_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-SALESTXREPT_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-ShipStats_1001’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-ShipStats_1002’.
[11/16/2018 11:08:04 AM] Import cancelled or failed for ‘TS-SuppOnTime_1001’.
[11/16/2018 11:08:05 AM] An error occurred while updating the entries. See the inner exception for details.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TS-SuppOnTime_1002’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TS-SuppOnTime_1003’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TS-SuppOnTime_1004’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TS-SupPORev_1001’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TS-WIPBALANCES_1001’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TS-WIPBALANCES_1002’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TSFREIGHTAUDIT_1001’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TSMFGINVSHEETS_1001’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TSMFGINVSHEETS_1002’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TSMFGINVSHEETS_1003’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TSPPREVIEW_1001’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TSSupPurchases_1001’.
[11/16/2018 11:08:05 AM] Import cancelled or failed for ‘TSSupPurchases_1002’.
[11/16/2018 11:08:06 AM] Finished importing Report Style definitions.
[11/16/2018 11:08:06 AM] Beginning the import of Report definitions…
[11/16/2018 11:08:23 AM] Import was successful for ‘1099’.
[11/16/2018 11:09:08 AM] Import was successful for ‘ApCheck’.
[11/16/2018 11:09:45 AM] Import was successful for ‘APPaymentEdit’.
[11/16/2018 11:10:25 AM] Import was successful for ‘ARAgng’.
[11/16/2018 11:12:03 AM] Import was successful for ‘AREdit’.
[11/16/2018 11:20:51 AM] Import was successful for ‘ARForm’.
[11/16/2018 11:22:24 AM] Import was successful for ‘BankReconEdit’.
[11/16/2018 11:23:38 AM] Import was successful for ‘BOMListingRpt’.
[11/16/2018 11:23:54 AM] Import was successful for ‘CntVar’.
[11/16/2018 11:24:17 AM] Import was successful for ‘CshREdit’.
[11/16/2018 11:25:49 AM] Import was successful for ‘CustSt’.
[11/16/2018 11:25:54 AM] Import was successful for ‘GLAccSummary’.
[11/16/2018 11:26:06 AM] Import was successful for ‘GLTrialBal’.
[11/16/2018 11:30:03 AM] Import was successful for ‘InspInvMovmnt’.
[11/16/2018 11:30:59 AM] Import was successful for ‘InvUsage’.
[11/16/2018 11:30:59 AM] Import was successful for ‘jobom’.
[11/16/2018 11:33:29 AM] Import was successful for ‘JobTrav’.
[11/16/2018 11:34:11 AM] Import was successful for ‘JournalEditList’.
[11/16/2018 11:36:58 AM] Import was successful for ‘MscPack’.
[11/16/2018 11:37:23 AM] Import was successful for ‘MtlTags’.
[11/16/2018 11:39:21 AM] Import was successful for ‘OrderAck’.
[11/16/2018 11:46:21 AM] Unable to process import for ‘Report’
ReportStyle: Output EDI should either be Plain Text or XML File.
Company=’’ ReportID=‘PackSlip’ StyleNum=‘1002’ StyleDescription=‘EDI’ RptTypeID=‘EDI’ PrintProgram=’’ PrintProgramOptions=’’ RptDefID=‘EDIPckSl’ CompanyList=’’ ServerNum=‘0’ OutputLocation=’’
[11/16/2018 11:46:21 AM] Unable to cast object of type ‘System.Exception’ to type ‘Ice.Common.EpicorTemplateException`3[Ice.Common.EpicorServerMessage,Ice.Common.ServerExceptionType,Ice.Common.EpicorExceptionData]’.
[11/16/2018 11:46:21 AM] Finished the import of data definitions.
[11/16/2018 11:46:21 AM] Removing temporary files.
[11/16/2018 11:46:22 AM] Build process completed.
Error Summary:
