UPS WorldShip and Vantage
Mark,
I can't remember exactly how I did the mapping but I did following the UPS
instructions and it worked for me. I do not know if I mapped multiple tables
or not. But the reason we are not using the Keyed Import into UPS is because
the Order Header has a Ship To but the Order\Line\Release may be different
so the question was how do we pull that in, in Keyed Import. So like most
people have responded they use some type of middleware to make that happen,
Access, XML, etc...
We are just started the Implementation of this. In the Work Order we
received it was for 24 hours worth of time, but my expectation of total time
should be 8 hours at most. It took the Consultant 2 hours to remotely to the
install and setup InSite and I figure the 6 other hours will be training for
the shipping staff.
I decided to put this off until after the holidays so we do not have
knowledge lost during the holidays.
I can let you know my progress as I go through it. But I have tested it on
my Test DB and just to be able to pull Order Shipping info into Customer
Shipment Entry and have the Tracking Number and Freight Charges get back to
the Shipping Document and Invoice will be such a time saver (we manually do
it now, though reading the bar code from the Manifest label via scanner
could be used) we think it is going to be well worth the cost in the long
run. Plus we then can use the Vantage Packing Stations to be able to ship
UPS or Fed-Ex and are not tied into going to that particular Manifest PC to
ship it with that carrier, we like that flexibility.
Scott
Mark Wonsil
Sent: Tuesday, December 11, 2007 3:04 PM
Subject: RE: [Vantage] UPS WorldShip and Vantage
> When I did try it I did not have any issues. I set up the ODBC connection
> and was able to read the Tables.
Were you using keyed import? I seem to recall that you can only choose one
ODBC source and from there I couldn't see where to map from multiple tables.
> But we then decided to move to using InSite
> Manifest to replace WorldShip and Fed-Ex. We are going to go live with
this
> January of next year and it looks like it everything we need it to be.
Talks
> directly to Vantage to send back Tracking Numbers and Freight Charges to
the
> Order\Line\Release it is shipping. Plus we still just use Vantage to do
> Customer Shipments so the Shipping Information is pulled in from
> Order\Line\Release, which in turns feeds this information to InSite to get
> the Tracking Number and Freight Charges.
How many consulting hours did it take? The price didn't seem too bad but we
were spooked by the $$$ for people to come out to install/setup; the
consulting was more than double the package. It looks like a good product
and
we heard good things about InSite but now InSite belongs to Epicor and quite
a
bit of functionality has moved to standard Vantage.
Mark W.
Yahoo! Groups Links
Anyone out there connecting to Vantage via an ODBC connection in UPS
Worldship? We are trying and getting an error, and are not sure what
it means.
Error From Worldship:
"Optional Feature Not Implemented
Server rejects connecting on attach
Drivers SQLsetconnectattr failed"
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 231
Fax: 870-423-3568
Web Site: http://www.kerusso.com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
Did you install the ODBC driver for OpenEdge on the Worldship PC?
Matt Caldwell
Sent: Tuesday, December 11, 2007 11:56 AM
Subject: [Vantage] UPS WorldShip and Vantage
it means.
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
Yahoo! Groups Links
Yes, and the Test Connect connects fine.
Of Scott Litzau
Sent: Tuesday, December 11, 2007 12:50 PM
Behalf Of
Matt Caldwell
it means.
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
have
and
Yahoo! Groups Links
> it means.
I've had no trouble getting the ODBC to work but once you do, it wasn't all
that helpful. At least the last time I tried, WorldShip would only link to one
data table when doing a keyed import. What makes it even more challenging is
when one line item is shipping UPS Red and another is plain old UPS Ground.
Currently, we run a VB program to update a SQL Server table that WorldShip
uses for input. I'm currently working on a BPM to update WorldShip. When
someone clicks Save on an order, it will launch an asynchronous .Net routine
to see if any of the lines are shipping via UPS. If so, it will add/update
records in the shipment table for Worldship. 8.03.400 has aligned many of the
fields with WorldShip and I'm updating the program now for that.
I'm starting to see how BPM is very powerful for doing things. It looks like
I'll cut down on some of the screen customization in favor of using a BPM hook
instead.
Mark W.
and was able to read the Tables. But we then decided to move to using InSite
Manifest to replace WorldShip and Fed-Ex. We are going to go live with this
January of next year and it looks like it everything we need it to be. Talks
directly to Vantage to send back Tracking Numbers and Freight Charges to the
Scott
Mark Wonsil
Sent: Tuesday, December 11, 2007 1:42 PM
> it means.
one
the
hook
instead.
Mark W.
Yahoo! Groups Links
consulting was more than double the package. It looks like a good product and
we heard good things about InSite but now InSite belongs to Epicor and quite a
Mark W.
Can't remember exactly, but we also had trouble, I ended up writing a small app that acts as a go-between from Access to Progress/vantage( Worldship uploads to Access, my app uploads Access to Vantage( shipping info such as Misc Charge, Tracking Number).
Matt Caldwell <matt@...> wrote: Yes, and the Test Connect connects fine.
Of Scott Litzau
Behalf Of
Matt Caldwell
it means.
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
have
and
Yahoo! Groups Links
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Matt Caldwell, contact Matt Drake at UPS/Crossware technical support:
mdrake@... . He will help.
Ian Hogan
Information Systems Manager
Standard Filter Corporation
760-929-8559 or 800-634-5837 (voice) - 760-929-1901 (fax)
Of Matt Caldwell
Sent: Tuesday, December 11, 2007 11:03 AM
Behalf
Of Scott Litzau
Behalf Of
Matt Caldwell
it means.
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
Web Site: http://www.kerusso.com <http://www.kerusso.com>
at: 800-424-0943
have
and
<http://groups.yahoo.com/group/vantage/files/> >
Yahoo! Groups Links
