Urgent Blank Title 98417
It should alert the user on "save".If a Po has several lines then all releases should be drop ship or all releases should not be drop ship.
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> OK, I uploaded an example to the files section.
> Description: Drop Ship e-mail Alert - BAM and .p program
> Filename = BAM_Alert_OrderRel_DropShip.zip
> --- In vantage@yahoogroups.com, "Anitha" <anithayedavalli@> wrote:
> > Yes pls
> > --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > > Are you trying to send an alert or do something to the other releases with a BPM?
> > > If it's just an alert, I have a BAM/alert I could send you.
> > > > Hi,
> > > > I need to set up an alert for PO.If sngle release on PO is flagged as Drop Ship,then all release must be drop ship.How do I do it?
> > > > Idea is sum of dropship>total lines of po order then attach alert.
> > > > Thanks
Hi,
Yes pls
> > Hi,
> > Thanks
