When i asked our internal AI ChatBot which also uses Kinetic’s “Epicor Knowedge Agent” (an AI Agent built into the cloud), I got the following answer:
What Use Estimates does
The Use Estimates checkbox controls how Kinetic distributes actual labor time when an employee is clocked into multiple operations at the same time.
When selected, Kinetic uses each operation’s estimated hours as the weighting basis for splitting the employee’s actual elapsed labor time across those concurrent operations.
In practical terms:
Actual labor time is apportioned by operation estimate, not split evenly and not necessarily assigned independently by clock duration.
Example
An employee is clocked into two operations at the same time for 2 actual hours.
| Operation |
Estimated Hours |
Share of Estimate |
Actual Labor Posted |
| Op A |
1 hour |
25% |
0.5 hours |
| Op B |
3 hours |
75% |
1.5 hours |
| Total |
4 hours |
100% |
2.0 hours |
Without Use Estimates, the distribution behavior depends on the burden/labor configuration and data collection logic, but Use Estimates specifically tells Kinetic to use the operation estimates as the apportionment driver.
Where it matters
It matters primarily in Data Collection / MES labor reporting, especially when:
- One employee is working multiple jobs or operations concurrently.
- Labor must be spread proportionally based on expected effort.
- You want actual labor cost to follow the routing estimate instead of naïve elapsed time allocation.
The Epicor help text states that when an employee clocks into multiple operations on the same resource group, Kinetic uses the estimated hours on each operation to calculate how much actual labor time to place against each operation. It also says that if the employee is clocked into operations across different resource groups and one relevant group/resource is set to Use Estimates, Kinetic includes the operation estimates when applying labor against each operation.
Resource Group vs Resource
The important distinction:
| Level |
Meaning |
| Resource Group Use Estimates |
Applies the estimate-based labor apportionment behavior for operations using that resource group. |
| Resource Use Estimates |
Same concept, but at the specific resource level where applicable. |
The documentation is clearer and more explicit for Resource Group Maintenance than for individual Resource Maintenance. It also notes that Split Burden and Burden = Labor are resource group burden-hour behaviors, while Use Estimates is available regardless of whether burden is calculated using Split Burden or Burden = Labor.
What it does not do
It does not change the job’s estimated hours.
It does not change scheduling capacity by itself.
It does not recalculate production standards.
It does not mean “use estimates instead of actuals” globally.
It is specifically about how actual labor time gets distributed when concurrent labor activity exists.
