User Fields version 8
So what happens when I put a user field in a blank location X. Then Epicor
updates the screen and puts a button or something in the same spot? You need
to look at all screen customization after you apply a patch incase something
doesn't fit or now overlaps? Is this how it works?
Patrick Winter
regalproto
Sent: Wednesday, April 12, 2006 7:47 AM
Subject: [Vantage] Re: User Fields version 8
In Vantage 8.0 there is a technology being utilized called Layered
customization which basically means that your customizations will stay
intact with version changes such as screen changes. You pick which screen
(when customizing a screen you save it as your own
version) will load via the System Management - Menu Maintenance.
Hope this helps,
Vicky Crnovrsanin
--- In vantage@yahoogroups.com, pjw@... wrote:
> So what happens when Epicor changes a screen that you have added
user fields
> too?
> Does your older screen get loaded instead of the new one?
> How do you know what version your custom screen is?
> How do you know a newer version is available?
> Patrick Winter
Behalf Of
> Chris Robisch
> Sent: Tuesday, April 11, 2006 11:59 AM
> Subject: Re: [Vantage] User Fields version 8
> The user fields, like part.userchar1, exist but they're not
supported in the
> standard forms... you have to customize the forms to reference
them. More
> custom fields have been added to many tables. There's a new one
called
> ShortChar## (50x) to handle relatively short fields.
> From: "Mike Lowe" <MLowe@...>
> To: <vantage@yahoogroups.com>
> Sent: Tuesday, April 11, 2006 9:13 AM
> Subject: RE: [Vantage] User Fields version 8
> Dave,
> Check to see if the labels have been defined for the user fields,
perhaps
> this is why they aren't appearing. I can't imagine that the
developers
> would totally omit these fields due to the potential impact on
older Vantage
> users that may use these fields. Before the "VB Form" days there
were
> heavily utilized if you needed to input user specific information.
> Mike
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf Of
> dave.miller2@...
> Sent: Tuesday, April 11, 2006 8:03 AM
> Subject: [Vantage] User Fields version 8
> We have been testing version 8 of Vantage and recently found out
that the
> user fields (Part File Maintenance) no longer exist. I was
wondering if
> anyone else currently uses these fields that has gone to or is
testing
> version 8 and what solution they have come up with.
> Thank you,
> Dave Miller
> Prince Industries, Inc.
must have
Builder and
> Yahoo! Groups Links
> This e-mail and any attachments may contain confidential and
> privileged information. If you are not the intended recipient, please
> notify the sender immediately by return e-mail, delete this e-mail and
> destroy any copies. Any dissemination or use of this information by a
> person other than the intended recipient is unauthorized and may be
> illegal.
Yahoo! Groups Links
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
We have been testing version 8 of Vantage and recently found out that the user fields (Part File Maintenance) no longer exist. I was wondering if anyone else currently uses these fields that has gone to or is testing version 8 and what solution they have come up with.
Thank you,
Dave Miller
Dave,
Check to see if the labels have been defined for the user fields, perhaps this is why they aren't appearing. I can't imagine that the developers would totally omit these fields due to the potential impact on older Vantage users that may use these fields. Before the "VB Form" days there were heavily utilized if you needed to input user specific information.
Mike
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of dave.miller2@...
Thank you,
Dave Miller
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
The user fields, like part.userchar1, exist but they're not supported in the standard forms... you have to customize the forms to reference them. More custom fields have been added to many tables. There's a new one called ShortChar## (50x) to handle relatively short fields.
Dave,
Mike
Thank you,
Dave Miller
So what happens when Epicor changes a screen that you have added user fields
too?
Patrick Winter
Chris Robisch
Dave,
Mike
dave.miller2@...
Thank you,
Dave Miller
Yahoo! Groups Links
You can export the customizations then import them after the release. We do this all the time since we're refreshing our v8 database from our live 6.x almost every release. I suspect standard forms won't be changed drastically. If they are, the customizations may have to be redone. So far, we haven't had to do that and we've been using v8 since the beta program started.
By the way, the JobAsmbl corruption issues we've encountered have all been resolved as of Patch 8.0.807a except one: copied assemblies get BomSequence value of 0. And Doug Williams of Epicor Development says Index BomSeq, which uses the BomSequence field, isn't used in any updating program. It exists for programs to display the job structure without needing a recursive routine.
We have an open issue where the PO Line grid customizations/layout can't be saved properly. We hate the PO line grid as a separate tab is used for each type (job, subcontracting, inventory and other). Then columns are moved around depending on the type. Whoever did this didn't think of cut/paste from Excel as the columns don't line up. So we align them ourselves. We rarely use multiple releases.
Sent: Tuesday, April 11, 2006 10:27 AM
too?
Patrick Winter
Chris Robisch
Dave,
Mike
dave.miller2@...
Thank you,
Dave Miller
Yahoo! Groups Links
Yahoo! Groups Links
stay intact with version changes such as screen changes. You pick
which screen (when customizing a screen you save it as your own
Hope this helps,
Vicky Crnovrsanin
user fields
> too?
> Patrick Winter
Behalf Of
> Chris Robisch
supported in the
them. More
called
> Dave,
perhaps
developers
older Vantage
were
> Mike
Behalf Of
> dave.miller2@...
that the
wondering if
testing
> Thank you,
> Dave Miller
must have
Builder and
> Yahoo! Groups Links
