User getting security error (You do not have security clearance for this option)
One user is getting the following error opening Move Inventory Request form
Menu Security
Allow Access to All Gorups/Users is checked.
Its just one user.
Business Layer Exception
You do not have security clearance for this option.
Error Detail
Description:  You do not have security clearance for this option.
Program:  Erp.Services.BO.MoveRequest.dll
Method:  CheckEmployee
Line Number:  181
Column Number:  17
Table:  MoveRequest
Field:  EmpID
Server Trace Stack:     at Erp.Services.BO.MoveRequestSvc.CheckEmployee(String empID, String& empName) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Services\BO\MoveRequest\MoveRequest.cs:line 181
   at Erp.Services.BO.MoveRequestSvcFacade.CheckEmployee(String empID, String& empName) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Services\BO\MoveRequest\MoveRequestSvcFacade.cs:line 71
   at SyncInvokeCheckEmployee(Object , Object[] , Object[] )
   at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
   at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
   at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
   at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\ICE3.2.200.10\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
   at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
   at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
   at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
   at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
   at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
   at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
   at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
   at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
   at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
   at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
   at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
   at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
   at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
   at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
   at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
   at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
   at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
   at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
   at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
   at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
   at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
   at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
   at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
   at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
   at Erp.Proxy.BO.MoveRequestImpl.CheckEmployee(String empID, String& empName)
   at Erp.Adapters.MoveRequestAdapter.CheckEmployee(String empID, String& empName)
This type of transaction requires special transactional security that is set in the Employee Maintenance screen… You need to set the checkbox true.
TY Tim,
That was it.
