User ID used in a BPM
I was out on other projects for a bit, now back to Vantage. I think I'm going to try a different route with the user ID because I can't seem to get that to work, but I have a problem where it looks like a simple query won't work either. It would appear simple... If the RMA line in the RMA processing screen has a receipt when a change is saved, it should send me an email, if not, do nothing. But I can't see how to get this one to work correctly. I am trying this currently(and tried many combinations there of) :
for each ttrmadtl , each rmarcpt where (ttrmadtl.RMANum = rmarcpt.RMANum and ttrmadtl.RMALine =
rmarcpt.RMALine) and rmarcpt.RMAReceipt = 1 no-lock.
Basically, if the RMA number and RMA line of the RMA has a record in the rmarcpt table, it should send an email to me after a save. I've tried numerous different ways and nothing works. Currently, if I do it as a regular query in the Method Directive Conditions, it never sends anything out, if I go in and use the Advanced area, it always sends email out regardless if there is a receipt or not. I have other conditions I'm going to add to this later, but this is my base condition and I need this to work first. Like I said, I've tried 100 different ways and I can't get any working results, can anyone help?? I do appreciate any help offered!!!
Regards,
Kurt
--- In vantage@yahoogroups.com, Dan Godfrey <dgodfrey@...> wrote:
> Cany ou isolate the user into a security group. If so, then there is a condition for the user belonging to OR not belonging to a specific group.
Hi all!
I'm trying to do a BPM for the RMA Processing screen. Basically, it is supposed to let only certain people make changes to the Reason Code after receipt. I think I have a portion of it figured out, but I can't seem to get the current user. Like 'If current user = "Fred" or current user = "John" then....' This would be after checking for the receipt (rmadtl = rmarcpt). But I can't get how to check the current user against specific names. I tried USERID and it does nothing, and I've seen somethings about DCD-USERID, but that just errors. I know there has to be something that is right in front of me, but I can't see it. Can anyone help on this? Thanks in advance for any help!
Regards,
Kurt
The variable is DCD-USERID. It should work.
What might be easer is to create a security group and then I think one
of the conditions on a BPM is to check that the user is part of a
security group.
That what you don't have to change your BPM as people come and go.
Of Kurt
Sent: Wednesday, January 19, 2011 4:21 PM
Subject: [Vantage] User ID used in a BPM
Hi all!
Regards,
Kurt
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Ditto what Joe said - definitely do this as part of security groups. That
way, any security admin can change it and it doesn't require someone to dig
into BPM's. Also, if you have multiple BPM's that are affected, you only
have to make one change to the group instead of having to change multiple
BPMs.
Kevin Simon
Joe Rojas
Sent: Wednesday, January 19, 2011 4:41 PM
Subject: RE: [Vantage] User ID used in a BPM
security group.
Behalf
Of Kurt
Hi all!
Regards,
Kurt
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us
of the company.
Thanks for your replies! But, I keep getting various errors when trying to use the DCD-USERID in the Method Directives..Compose Query screen. What syntax would you use to check if someones user id equal a specific name? DCD-USERID = "John Smith" ? This is where I get errors. The other syntax I'm getting through, but this is giving me a problem. Can you help on this? Again, thanks for all your help!!
Regards,
Kurt
> BPMs.
> Kevin Simon
> Joe Rojas
> security group.
> Behalf
> Of Kurt
> Hi all!
> Regards,
> Kurt
> of the company.
I'm pretty sure that you can only put queries in the Compose Query
screen, not just any code. Or in other words, a query where rows from a
table are returned.
In this case, you would want to use the condition that says something
like "the user belongs to specific security group".
You want to still check the actual user id, then you will need to go
into advanced and where your own ABL code.
Keep in mind that DCD-USERID contains the user's username not there full
name.
If this case, it would look something like:
If DCD-USERID = "jrojas" then
Do something
Else
Do something else
Of Kurt
Sent: Thursday, January 20, 2011 8:42 AM
Subject: [Vantage] Re: User ID used in a BPM
Regards,
Kurt
That
to dig
only
multiple
> BPMs.
> Kevin Simon
Behalf Of
> Joe Rojas
> security group.
> Behalf
> Of Kurt
> Hi all!
current
has
> Regards,
> Kurt
the
e-mail.
this
this
those
> of the company.
