User Session time-out v8
Jennifer,
We use this feature and it works fine. We are also running 811b. The
only problem with it is that we have to log into administration after
someone has timed out and delete the log in record.
Jason Abramczyk
Precision Parts
Of Jennifer
Sent: Friday, 24 August 2007 11:00 AM
Subject: [Vantage] User Session time-out v8
Has anyone used the time-out feature in User Maintenence? I tested it
today and it didn't seem to be working. v.8.0.811b
Jennifer Mesiano
IT Manager
Walton Signage
Jennifer Mesiano
IT Manager
Walton Signage
--- In vantage@yahoogroups.com, "Jennifer" <jmesiano@...> wrote:
After the timeout period has expired, the system tries to only take
your license if all the licenses are in use and someone else tries
to log on. Even if you do lose your license, when you try to use
the system again, if there is a license available to you, it will
appear as though you never lost it.
-Peter Volkert
it
> Jennifer Mesiano
> IT Manager
> Walton Signage
Jennifer,
How did you test it?
I came across a second document once that contradicted the first I read.
I believe that the time out feature does not actually time-out and disconnect the session, but after the period of time, will allow the license to be recoverable by a different user who logs on to the server, and when attempting to acquire a license when they are all "in use" will then be able to recovery the license from the other account whose session has exceeded the time-out period.
With that being said, I can still not vouch for the success of the code and methodology, but it may explain why you are not seeing the results you expect.
Carey
To: vantage@yahoogroups.comFrom: jmesiano@...: Fri, 24 Aug 2007 00:59:36 +0000Subject: [Vantage] User Session time-out v8
Has anyone used the time-out feature in User Maintenence? I tested it today and it didn't seem to be working. v.8.0.811bJennifer MesianoIT ManagerWalton Signage
_________________________________________________________________
Learn. Laugh. Share. Reallivemoms is right place!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
