Users get kicked out of Vantage 6.1
Thanks, I will try what you have suggested!
Wish me luck...
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@...> wrote:
> There has been a long standing issue with these symptoms and, as
far as I know, there has never been a solid resolution. But looking
back in my message archives I found a list I had sent out once with
things that might help Crystal based reports (in CR 8.5 for Vantage
6.1).
> Below is the check list I have extracted from various archived mail
messages from many group members and things I have had success with
from time to time. Sorry if this wraps badly when Yahoo passes it
along. This checklist is pretty much related to only freezes when
printing Crystal forms. If anyone has other things to add please do
so and suggest where in the list they should go (as far as most---
>least likely to help).
> Roughly in order of what to try first
> 1. Download and update the latest CR85 patches from the Epicor FTP
site (Vantage\Crystal folder)
> Note: The one in Vantage\Crystal is a newer zip file than in
the mfg6\Crystal folder - if that matters
> 2. Update Crystal development PC(s) with the patch
> 3. Update Client PCs with the database-export patch (fixes missing
details issue and perhaps others?)
> 4. Compare all Crystal DLL version on the development PC with the
Mfgsys61\DLL folder
> 5. Any that are newer on the development PC
> A) Rename the current one in Mfgsys61\DLL to preserve it
(append -old to extensions)
> B) Copy development PC version to Mfgsys61\DLL
> 6. Copy all CR type .DLL files from the Mfgsys61\DLL folder to the
client's system32 (or system) folder
> 7. Also copy P2BXBSE.DLL to the client
> 8. Make double sure CRPE32.DLL on the client is same as Mfgsys61
\DLL version
> 9. Copy Sscsdk80.dll in the Program Files\Seagate Software\Shared
folder to the client System32 folder
> 10. Also find sscsdk32.dll and copy it
> NOTE - the above file(s) if not on client can bomb Crystal
reports that have graphic images (logos)
> 11. Run forcereg.bat on client (note possible errors in file
locations in Mfgsys61 version - edit to check)
> 12. If Windows 98 replace the spools.dll file with one from Windows-
ME
> 13. Change driver on HP LaserJet printer to HP-LJ II or similar old
driver
> 14. Create a distributed report (any will do) and distribute to the
client (will shape up some .DLLs on the client)
> 15. Scan the registry for all references to old Progress versions
and old servers and delete them
> - backup the registry first!!!!
> 16. If using some other software with Crystal as a Reprot Writer
tool (like FAS or ADP) the .DLLs for those can clobber the ones that
match Epicor's Crystal based reports and the server based DLL's they
depend on. Some of the above suggestions will resolve this BUT
easier still to verify it is to uninstall the offending report writer
(manually check and uninstall all CR related DLLs) and re-install the
Vantage client and see if that makes the problem go away.
> 17. Try keeping the MFGWRK61 folder empty.
> 18. Re-install the printer as a new name and use an older more
generic driver.
> Suggestion: Stop after each step or two and see if the problem
went away so that you know what was probably the problem.
> There was another routine I saw once called RegProgDLLs.exe that
had something to do with setting the registry for Progress .DLLs.
There could be some hooks to Crystal in there that might be an
issue. Probably have to obtain this from Epicor Support and they can
say if it is relevant or not.
> -Todd C.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf Of mcdonaldrichards
> Sent: Wednesday, January 24, 2007 2:02 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Users get kicked out of Vantage 6.1
> I have several users being kicked out of Vantage 6.1 while printing
> and it seems to be getting worse. I have 1 user in particular that
is
> being kicked out to an annoying degree and it doesn't appear to
have
> any consistency with what she is doing; she loses her connection
and
> has to restart. Has anyone else had this problem? Any solutions?
> Tiffany McDonald
> Systems Administrator/CNC Programmer
> Richards Sheet Metal Works
> 2680 Industrial Drive Ogden, UT 84401
> Phone 801.621.3341
> Fax 801.392.9567
and it seems to be getting worse. I have 1 user in particular that is
being kicked out to an annoying degree and it doesn't appear to have
any consistency with what she is doing; she loses her connection and
Tiffany McDonald
Phone 801.621.3341
Fax 801.392.9567
Yes, it happens here mostly when printing A/R invoices. It can happen
when printing individually and as a group.
Never have been able to figure out why.
Jeni Wilson
Boyer Machine
Of mcdonaldrichards
Sent: Wednesday, January 24, 2007 3:02 PM
Tiffany McDonald
Phone 801.621.3341
Fax 801.392.9567
Are the problem workstations W98? If so, and if any user gets a "Maximum
number of users exceeded" when there aren't enough licenses available, then
anything can go wrong with the workstation in almost any program, not just
Vantage. Epicor has no solution other than to upgrade to W2000/XP. I've
advised my users that when they can't get into Vantage - stop everything and
reboot - otherwise they'll have all sorts of problems and the PC will
eventually crash.
Norm Watkins
Engineering Manager
ELECPAC
Phone: 847-639-2307
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of mcdonaldrichards
Tiffany McDonald
Phone 801.621.3341
Fax 801.392.9567
Yahoo! Groups Links
There has been a long standing issue with these symptoms and, as far as I know, there has never been a solid resolution. But looking back in my message archives I found a list I had sent out once with things that might help Crystal based reports (in CR 8.5 for Vantage 6.1).
Below is the check list I have extracted from various archived mail messages from many group members and things I have had success with from time to time. Sorry if this wraps badly when Yahoo passes it along. This checklist is pretty much related to only freezes when printing Crystal forms. If anyone has other things to add please do so and suggest where in the list they should go (as far as most--->least likely to help).
1. Download and update the latest CR85 patches from the Epicor FTP site (Vantage\Crystal folder)
Note: The one in Vantage\Crystal is a newer zip file than in the mfg6\Crystal folder - if that matters
3. Update Client PCs with the database-export patch (fixes missing details issue and perhaps others?)
4. Compare all Crystal DLL version on the development PC with the Mfgsys61\DLL folder
A) Rename the current one in Mfgsys61\DLL to preserve it (append -old to extensions)
6. Copy all CR type .DLL files from the Mfgsys61\DLL folder to the client's system32 (or system) folder
8. Make double sure CRPE32.DLL on the client is same as Mfgsys61\DLL version
9. Copy Sscsdk80.dll in the Program Files\Seagate Software\Shared folder to the client System32 folder
NOTE - the above file(s) if not on client can bomb Crystal reports that have graphic images (logos)
11. Run forcereg.bat on client (note possible errors in file locations in Mfgsys61 version - edit to check)
12. If Windows 98 replace the spools.dll file with one from Windows-ME
13. Change driver on HP LaserJet printer to HP-LJ II or similar old driver
14. Create a distributed report (any will do) and distribute to the client (will shape up some .DLLs on the client)
15. Scan the registry for all references to old Progress versions and old servers and delete them
16. If using some other software with Crystal as a Reprot Writer tool (like FAS or ADP) the .DLLs for those can clobber the ones that match Epicor's Crystal based reports and the server based DLL's they depend on. Some of the above suggestions will resolve this BUT easier still to verify it is to uninstall the offending report writer (manually check and uninstall all CR related DLLs) and re-install the Vantage client and see if that makes the problem go away.
18. Re-install the printer as a new name and use an older more generic driver.
Suggestion: Stop after each step or two and see if the problem went away so that you know what was probably the problem.
There was another routine I saw once called RegProgDLLs.exe that had something to do with setting the registry for Progress .DLLs. There could be some hooks to Crystal in there that might be an issue. Probably have to obtain this from Epicor Support and they can say if it is relevant or not.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of mcdonaldrichards
Tiffany McDonald
Phone 801.621.3341
Fax 801.392.9567
