I am trying to add a Miscellaneous line to AR invoices with a BPM and code.
I am trying to use the business Object to create the new miscellaneous line, but I can’t find the correct code to define the tableset.
I think the code should look like this:
var svcInvcMisc = ServiceRenderer.GetService<Erp.Contracts.ARInvoiceSvcContract>(Db);
Erp.Tablesets.ARInvoiceTableset tsARInvoice = new Erp.Tablesets.ARInvoiceTableset();
But I get a Compilation Error that looks like this.
Error CS1936: Could not find an implementation of the query pattern for source type 'Erp.Tablesets.ARInvoiceTableset'. 'Where' not found.
var svcInvcMisc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.ARInvoiceSvcContract>(Db);
might need to be specific about your ServiceRenderer class. I did a test with that and it worked just fine
Thanks for your help with this. Confirming that the code worked for you made me look more closely at the rest of the code and the error came from how I was using the tableset not its setup.
