Using a .txt file as a datasource for a crystal report
I got it. I was using My.Computer.FileSystem.WriteAllText before which I believe converted the ascii code to text before it passed it to the .txt file as input. Alternatively, I used StreamWriter WriteLine() which worked - rather than converting the whole thing to text it just used the Ascii code to create the quotes. I may or may not be wrong on my assumption - at least it worked...
--- In vantage@yahoogroups.com, "drew.pete" <drew.pete@...> wrote:
> So far so good in using a .txt file as a datasource. My only roadblock is replicated keystrokes to create " in the text file. Here is the code I'm using to create the .txt file from my Epicor...
> Chr(34) & NameHeader & Chr(34) & "," & Chr(34) & DateAccessed & Chr(34) & VbCrLf
> Both NameHeader and DataAccessed are Field Names as type String.
> Chr(34) does create what looks like quotes, but it must be different in some way to the quotes I would create by input directly from my keyboard. When I use the asci code Chr(34) my report doesn't distinguish my field names at the beginning of the datasource - making the report inoperable. It also gives them very strange names. However, when I go into the .txt file I generate from the code, delete the existing quotation marks and replace it with quotation marks from my keyboard input the crystal report distinguishes the field names perfectly.
> Does anyone know the true difference between a keyboard generated quotation mark and that which is written using asci code? I feel like if I can bridge this gap I can solve my problem.
> Thanks in advance for any feedback,
> Drew
Drew
