Epicor leaves a lot of ICE stuff in the root of the C drive, from what I remember, I believe I may have deleted it. Without reinstalling the entire environment, is there anyway to restore ICE?
Whats the reason?
So I can get the install back to the way it was, I deleted it by mistake, I want to put it back.
Where are you talking about, server/appserver , client etc
this is on the server, I believe I deleted an ICE directory on the root
Any help on this would be greatly appreciated? At the root of your epicor’s server C drive, if you did not change the install path, do you see any ICE directories?
There are generally no Ice directories when you install Epicor on the server certainly not on the root of the drive.
What specifically are you looking for? What was in this folder that you now need?
thats the thing I am not sure of, I could have sworn I deleted a directory with the word ICE in it in the root, if you are saying its not there then it might have been nothing. Thank you
thanks for your help
